Cost for Spark Plug Change?
Old Sep 10, 2010 | 11:57 PM
Five Oh Brian's Avatar
Originally Posted by AFChief
They will SQUEEK like *****. Don't panic. And don't forget the anti -seize on the threads of the new plugs.
Foul on the play! The TSB specifically says to NOT put the anti-seize on the threads! Just on the barrel, and not to get any on the electrode, either. The barrel is where the carbon builds up. If you anti-seize the threads, the plugs will have a tendancy to loosen and back out!
Old Sep 11, 2010 | 07:34 AM
AFChief's Avatar
You are correct (on the TSB), however, A/S on threads is a common practice.
Old Sep 11, 2010 | 08:12 AM
thedrod's Avatar
Having changed my plugs again later due to the Brisks being total garbage, I wouldn't use anti seize period unless you are using two piece plugs as a replacement.
Old Sep 11, 2010 | 10:56 AM
jedikd's Avatar
Yah i'm putting in the Champion one-piece plugs so no anti-sieze.
Old Oct 23, 2010 | 09:20 AM
QCmustang's Avatar
I changed the sparks on my v8 04 explorer yesterday. Patience and experience is needed. A good idea is to put a bit of anti-seeze on the rubber boot of the coil on plug before putting them back on and to ----wait----- that the motor is (room tempereture before removing unscrewing). Will do the stang next week. Hope this helps someone!
Mpaps
Oct 11, 2017 08:06 PM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
GLOCKer
Sep 28, 2015 05:20 PM
southern stang
Sep 26, 2015 04:19 PM
Sep 23, 2015 03:21 PM
