Coolant Thermostat
Old 10/17/05, 05:40 PM
tmcolegr's Avatar
Thumbs up
Can someone please tell me the temperature rating on the OEM thermostat? I just installed my Autometer gauges and the coolant temp. is consistently between 195 - 200 degrees F. I presume the OEM themostat is close to that temperature. Factory gauge shows to be in the middle of the normal range.
Old 10/17/05, 06:01 PM
9 is not my lucky number.
dustindu4's Avatar
180 i think
Old 10/17/05, 06:08 PM
05STG1's Avatar
Too high..
180 for the GT's
195 for the v6's
Low fan kick on @ 214F
High fan kick on @ 225F
Old 10/17/05, 06:30 PM
tmcolegr's Avatar
Too High???
Please explain. The temp. has never gone over 200 degrees (ususally averages about 195) and the factory gauge does not indicate an overheat condition. Could be where the Autometer sender is located. If the low fans don't come on until 214 Degrees F. I wouldn't think this is too hot. Opinions are welcome.
Old 10/17/05, 07:07 PM
05STG1's Avatar
When I said too high...I mean that I personally would like it to run a little cooler...thats all.
My gauges match your temps.Fan on/off temps could always be changed if one had the urge, and tuner of course.
But...I personally dont like the sending unit there. I like a cleaner look, so I installed mine in the block. Just removed the plug on the left side, and installed the unit.
Old 10/17/05, 07:15 PM
dustindu4's Avatar
http://www.rpmoutlet.com/05gtfan.htm
That will fix your problem
unnoticedtrails
7/17/17 11:10 AM
Bullitt 3309
8/2/15 10:20 PM
NC14GT
8/2/15 07:27 AM
EleanorsMine
10/6/04 04:16 PM
Quick Reply: Coolant Thermostat
