Changed my oil with spec amount, still reads low.
Old Jul 30, 2008 | 02:51 PM
tdbrown75's Avatar
Just to confuse everyone, the "shop manual" specifies a 6.5 quart capacity. See my "dipstick" thread for more information: http://forums.bradbarnett.net/showpo...7&postcount=20
Tim
Old Jul 30, 2008 | 02:53 PM
08VistablueGT's Avatar
Originally Posted by 05YellowGT
+1 on marking the dip stick. I have to check mine on an angle so the first time I filled it with the specified 6 quarts , the next morning when it was absolutely cold and all the oil was in the pan I marked the dip stick where the level was ...
Ah that's a good idea.
tdbrown75, in that thread you state that adding 6 is the safest to do? I mean, when you buy oil from Brenspeed, they only give 6 quarts to you.
Old Jul 30, 2008 | 03:08 PM
tdbrown75's Avatar
As you have discovered, although the manual says 6 quarts, it does not necessarily top off the oil level completely. That's because the engine with Motorcraft filter actually holds 6.5 quarts. But since you can't drain ALL of the oil out, 6 quarts gets it in the safe range.
There has to be some variance depending on how much is left in the engine during a change, so 6 quarts may or may not necessarily get you precisely full and some may choose to top off some. The important thing to remember is that so long as the level reads between the two holes on the dipstick its fine.
Tim
Old Jul 30, 2008 | 03:59 PM
Tim
Ok Tim, well explained! Thanks a lot!
Old Jul 31, 2008 | 11:27 AM
metroplex's Avatar
My 07 GT reads exactly FULL with 6 quarts of oil and a new FL-820-S. It is the first Ford/car that I've seen that reads FULL with the specified engine oil fill capacity. Usually it always reads about 0.5 qt low.
Old Jul 31, 2008 | 02:24 PM
Hmmmmm very interesting...
jc46002003
Apr 15, 2016 03:00 PM
EaterofWorlds
Nov 23, 2015 08:51 PM
dohc97
16
Sep 24, 2015 05:40 PM
bigaaron
1994-2004 V-8
Aug 22, 2015 12:06 PM
C Moe
Aug 11, 2015 01:58 PM
