40 amp BAP work for our cars?
Old Jul 30, 2008 | 01:10 PM
08VistablueGT's Avatar
As the title says. I found a great deal on a 40 amp BAP, but will it be ok for my 08 GT? I was under the impression that you use a 40 amp (opposed to a 20 amp) for dual pumps.
Old Jul 30, 2008 | 06:33 PM
RedFire281's Avatar
Legacy Supercharged Tms Member
I've been using a 40 amp BAP for over a year and it works like a charm. If you're going over 500 rwhp I would recommend dual fuel pumps instead of the BAP. One or the other under 500 rwhp, you don't need both.
Old Jul 30, 2008 | 09:34 PM
Sounds great! Thanks a lot!
Old Jul 31, 2008 | 04:51 AM
jamesdem1123's Avatar
redfire did you wire yours up with a boost/vacuum switch or always on? im going to be running a 125+ hp shot of nitrous and will b running a bap (bought from brenspeed...)
Old Jul 31, 2008 | 05:43 AM
tom281's Avatar
You should ask Dave at Brenspeed, but I can tell you for blown applications they run the BAPs "always on" at the highest setting.
Old Jul 31, 2008 | 07:28 AM
Derek@DRI's Avatar
Yes a 40amp BAP will work on a Dual Pump setup, and we also like to run them 100% all the time.
Old Jul 31, 2008 | 02:25 PM
No, I know it will work on a dual pump set up. That's what the difference is between the 20 and 40 amp application. My question is, will the 40 amp work on a single (stock 08 GT) fuel pump?
Old Jul 31, 2008 | 03:19 PM
Derek@DRI's Avatar
My fault, yes it will work on a stock single fuel pump.
Ecostang
Nov 3, 2022 08:50 PM
ssjbuu
Aug 28, 2015 08:55 AM
K.A.I.N
'10-14 Interior and Audio
Jul 20, 2015 06:42 AM
Jul 20, 2015 06:26 AM
Kev006
Jul 8, 2015 05:29 AM
