View Poll Results: Which Supercharger would you get?
Vortech V-2 S trim
20.69%
Vortech V-2 HO System
17.24%
Paxton 1200
0%
Paxton 2200
34.48%
Procharger P-1SC-1
17.24%
Procharger D-1SC
10.34%
Voters: 29. You may not vote on this poll
Centrifugal Supercharger questions
#41
Lots of people use BAPs. I used one for a year..... however they, like alot of aftermarket parts, can fail whereas the GT500 system offers OEM reliability.
#42
Even OEM stuff prematurely fails.. guess we're all rolling the dice!
#43
#44
Alrighty, after doing a bit more research, I've found that superchargersonline.com also carries the stage II kit. Here's the catch, you have to call up and ask for it. Not really a big deal considering it retails for $56xx and they've got it listed for $48xx + $100 to ship. And, you can get HTO spark plugs for $80 with free shipping if you get it all together. Now that's what I call a good deal. That's what I'm eyeballing now.
#45
Curious, does anyone have any hard data (forum posts, articles, etc.) of the BAP failing?
#47
#48
I can say that in one-on-one talks with Brent and Dave at Brenspeed, they have installed hundreds of KB BAPs and have only had a handful fail. No catastropic engine failures, however I do agree that engine damage could easily occur from running out or low on fuel pressure.
But, it could also occur on bad gas, high heat, premature detonation, too much boost, blah blah blah. You're pretty much gambling on several key aspects when you decide to get blown.
#49
I’ve read of BAP failures on ModularFords. Like I said before, for the extra 200-300 dollars I went with the GT500 pump. It allows room to grow (600+whp), comes with an extra FPDM, and is an OEM drop in application. FP duty cycle will be lower as well. It was a no brainer to me.
#50
Anyone else hear of that?
#51
Yes, but that's only when it's installed a certain way, I believe per some manufacturer's instructions. Where as most people (like Brenspeed) run the power wire right up to the battery.
I will agree that the GT500 system is a better route but will argue that 95% of people with blowers can run a KB BAP and be just fine.
#52
#53
#54
Well I've had the GT500 pumps for about a month now, and have logged PLENTY of WOT romps and no blown fuses here. When time permits, search the forums, I believe there was a thread about this issue just a couple of weeks ago.
#55
I've never had an issues with blown fuses with my GT500 pump kit. I do need to pull mine because one of the tubes I believe had come undone. I ran out of gas the other day at work with 1/4 tank of gas left.
