C&L Intakes and JET T/B Spacers
Old Jun 28, 2006 | 11:48 AM
MaverickMLFD371's Avatar
For those who have this setup or have had this setup, I just found a really great deal on a C&L intake that i just bought, should be here in a couple of days. Any kind of modifications you had to make in order to make the C&L fit with the T/B Spacer? Anyone have to get a different PVC vaccumm hose?? Anyone have pics?
Chime in please....
Old Jun 28, 2006 | 12:29 PM
st06vert's Avatar
What is a t/b spacer? Thanks I saw you mention that on other post and it eliminates the throttle lag. What does t/b stand for and where can you get this? Thanks
Old Jun 28, 2006 | 12:51 PM
CIVEStang's Avatar
Throttle Body Spacer, and just about every aftermarket supplier has them
Old Jun 28, 2006 | 05:04 PM
packhater's Avatar
What deal did you get????? I'm getting ready to order mine as well.
Thanks!
Old Jun 28, 2006 | 11:52 PM
FireFighterHill's Avatar
I have the C&L and the JET TBS everything will fit but just barely. Just be careful and take your time on the install.
Old Jun 29, 2006 | 12:09 AM
Wardog 07's Avatar
Here's a pic of mine. Had to off-set the "tube" just slightly, to clear the coolant tank.
Also, I just replaced the vent tube with a hose, not pretty but effective.
Attached Thumbnails C&L Intakes and JET T/B Spacers-jet.jpg
Old Jun 29, 2006 | 06:20 AM
yea looks like i'll need to get a new PVC vaccumm hose. any one know what size to get? can these hoses be found at home depot or lowes?
Old Jun 29, 2006 | 09:35 AM
odiaz's Avatar
I was able to install the C&L and the TB spacer without any problems. The fit is tight. I was able to use the vacuum hose that came with the car. It's stretched tight but it snaps solid into place.
A few clearance problems to be aware of; check the clearance between the C&L and the following components:
1) radiator overflow tank
2) Power steering reservoir
3) radiator hose underneath c&L
The best procedure I found is to install everything and leave all the clamps loose. Move the C&L so that you have some clearance between all of the componets listed above and then tighteten all the clamps. The entire install takes about 15minutes.
Attached Thumbnails C&L Intakes and JET T/B Spacers-engine.jpg
Antigini-GT/CS
Oct 5, 2015 09:43 AM
RoushRS3
Sep 29, 2015 08:03 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
