Brisk 3v (silver) spark plugs vs. Champion 3v double platinum
![](https://themustangsource.com/forums/images/ranks/veteran_army.png)
The dealership may be able to deny liability because it is a design flaw that they have no control over.
A good service manager would find a way to help the customer recover costs though.
Ford can be sued for a design flaw that causes damage to a vehicle.
A class action lawsuit could initialize a recall. (This would probably only change the plugs to a 1 piece design, not the heads)
Just my 2 cents.![Dunno](https://themustangsource.com/forums/images/smilies/dunno.gif)
Just my 2 cents.
Although Ford can be sued for a design flaw that causes damage to a vehicle. A) I don't consider plugs breaking inside the cylinder head, as causing damage to a vehicle, when being directly related to spark plug removal. B) And even if there was, it would cost you more money to fight it out in court, than what it's really worth it.
On the other hand, I definitely agree that Ford should " at least" change the plugs to a one piece design. At least that would be a fine start.
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
Okay - this is right from the 2006 Ford Warranty:
• your vehicle or engine is designed, built, and equipped to meet - at the time it is sold - the emissions regulations of the U.S. Environmental Protection Agency (EPA).
• your vehicle or engine is free from defects in factory-supplied materials or workmanship that could prevent it from conforming with applicable EPA regulations.
• you will not be charged for diagnosis, repair, replacement, or adjustment of defective emissions-related parts listed under What is Covered?. (Spark plugs ARE listed under "What is Covered?")
So as I read this, I should not be charged to repair a defective spark plug. So, if I take my car in to have the plugs changed, and one or more breaks in the head due to carbon build-up (a Ford-acknowledged issue), then the spark plug is defective and should be repaired/replaced under the emmisions warranty.
Granted, the defect isn't apparent until the plug breaks, but once it does, the warranty should apply:
EMISSIONS DEFECT WARRANTY COVERAGE
During the warranty coverage period, Ford Motor Company warrants that:
Diagnosis - carbon-fused spark plug resulting in breakage upon attempted removal
Repair - remove remaining plug parts with special tool.
Replace - new plugs.
The way I read it, and I don't see how it can be read another way, Ford HAS to pay for the repair if the plugs break as long as the car is within warranty.
The Fedral Mogul rep was in my store yesterday touting the new champion one piece
plugs. They look like they have the issue solved, so I ordered a set for my 06.
My car only has 13k miles on it and I live at the rev limiter so I dont think ill have a carbon issue, but I'll change the plugs anyway.
Jay
Where did you get Champion 1-piece plugs for $4.95 a piece and are these Platinum/Iridium plugs? Last I saw they wanted nearly $20 per plug:
http://www.championsparkplugs.com/re...p?AAIA=1431310
$18.99/piece
The OEM plugs are $7-$8/piece at RockAuto. IIRC they were much more expensive when the 3V engines first debuted.
I would avoid silver tipped plugs because silver does not have the same durability as platinum/iridium. Silver also tends to oxidize faster than other metals. Perhaps a racing application may benefit from copper or silver plugs, but I am a believer in platinum/iridium plugs for everyday use.
I have an early 2007 GT and am not too concerned about the plugs. I *may* have to change them in the year 2020.
My plan is to wait for a 1-piece 3V iridium plug.
$18.99/piece
$18.99/piece
$18.99/piece
That's a misquote. They're listed at $15.95 on their website, although the search results show $4.95. If you add it to your cart, it's $15.95/plug.
Part #
![](https://store.summitracing.com/images/browse_images/spacer.gif)
CPN-7989
You're right about the website. Guess they're jacking up the price. But they can't charge me anymore rhan $4.95.
Rash: Yes, Summit is a very reputable company. I bought Addco anti-roll bars from them years ago and they charged me a ridiculously low price. I figured it was just for the bare bars... but instead I received the full kit with red powdercoated bars. It apparently was a misprint/misquote but they still honored the reduced price.
I figure the Champions are going to retail close to $18-$19/piece. My prediction is that it will drop in price in the next few years as there are quite a few 3V heads being used in the US (MY 04-07).
Champion #7989
I was one of the lucky ones that got the Champions at $4.95. The letter I got from Summit says the actual price will be $12.95. I hope to install the Champions this weekend. The new POS Motorcrafts the dealer installed (with anti-seize) have been in less than 3,000 miles so hopefully they will come out OK. Oh yea, I'm the one that had 6 of 8 plugs break off at 38,000 miles on the clock. Ford should bleed for this screw up.
I feel like a jerk for that comment. Summit sent a letter explaining that they should have been $12.95, but that they're honoring the $4.95 this time. They also threw in a baseball cap. So let me rephrase my comment - they COULD have charged me more than $4.95, but were classy enough to honor the lower price in a customer-friendly, professional manner. Thumbs up to Summit - they've earned my future business,
Summit sent a letter explaining that they should have been $12.95, but that they're honoring the $4.95 this time. They also threw in a baseball cap. So let me rephrase my comment - they COULD have charged me more than $4.95, but were classy enough to honor the lower price in a customer-friendly, professional manner. Thumbs up to Summit - they've earned my future business, ![Thumb](https://themustangsource.com/forums/images/smilies/thumb.gif)
I've been buying from Summit for nearly a decade. They are by far one of the best internet car part/accessory vendors. Jegs is also a great vendor for car parts. They used to offer discounts periodically.
If you're into guns, Midway USA and Brownells are the "Summit Racing" of gun parts/accessories.
You might want to experiment with silver solder like the stuff used to "permanently" attach flash suppressors to a barrel (e.g. 14.5" M4 and a Phantom 5C2).
this plug issue is going to end up like the 2V engines and there manifold defect. ford willl get sued by tones of people before it is fixed. i beleive it took 6-8 years before 2V owners got a settlement.
1) <snip>
2) Platinum in a spark plug is there for durability, not performance. A Brisk silver or even an alternative made of copper would have a lower resistance and therefore more spark energy for better performance. My car runs noticeably smoother with the Brisk spark plugs. Platinum will last a little longer, but none will last a full 100,000 miles without noticeable degredation. .
I'm not doubting you when you say your car runs better with the Brisk plugs. I AM doubting that the super thin coating of precious metal on the top of the factory plug has anything to do with that difference.
I just wish Pulstar would build a plug for our cars. They basically stuff a capacitive ignition inside the plug. Most importantly, it is past the resistors in the plug and wire, so it can dump a LOT of energy VERY quickly when the plug fires. More than an external CDI can do.
The theory is good at least.
9/23/15 03:21 PM
