BMR Lower Control Arm Relocation Brackets Are On
The BMR brackets definitely reduced my 60' time a little!
Same here. I just ordered a Metco Adjustable UCA - will see if it helps any.
I still haven't checked the bushings in my LCAs yet...
As does mine...they're currently off
Originally posted by Hatchman@November 5, 2005, 6:53 AM
Dan, you getting any wheel hop with this setup? I've got the regular non adjustable BMR LCA's, and still getting intermittent wheel hop out of the hole. I was using stock tire pressure, which might be an issue. Sometimes it hops, sometimes it's smmmooooth.
And yes, I'd ditch the weights. Mine whines with or without them.
