Blown GT's w/450+ rwhp, how y'all holding up?
Old 10/22/10, 09:11 AM
  #41
J. Dub's Avatar
Originally Posted by NastyStang113
Roush TVS at ~11 lbs tuned by VMP Tuning, stock motor, stock heads/cams, stock exhaust manifolds etc etc. Only mods that add power are the Roush TVS, O/R X Pipe, and Magnaflow catback. OEM TR3650 with updated syncros from TSB with McLeod RST. OEM rear differential and gears.
525 rwhp 501 rwtq.
Over a year.
Drive it every day, race it, and beat on it constantly.
Nasty, any supporting mods? Like beefed up splines in the rear axle, built driveshaft, supporting mods for the SC like catch can, ect.... All the small stuff that adds up. Do you have a list of that?
I ask cause I, like you, daily drive my stang.
Old 10/22/10, 09:38 AM
  #42
J. Dub's Avatar
Originally Posted by firestang70
I run stock pump with a BAP. I run 10 lbs boost, 39# injectors. My duty cycle on my fuel pump is in the acceptable range. I will upgrade with the GT500 pumps when I add boost later. You will be OK with 450 rwhp with stock pump and a BAP.
What if we're only running 8lbs of boost on a m90? Would we even need a BAP?
Would the stock fuel pump be suffice? Would upgraded injectors be needed?
Old 10/22/10, 09:42 AM
  #43
IMHO yes you would need the BAP, but the GT500 dual pumps are better, and yes you would need the 39# injectors. Also you would need a different tune. If you tinker with the kit at all, you will need a new tune.
3/30/21 09:29 AM
09-gt/cs
10/15/15 10:03 AM
10/2/15 01:00 PM
Kalel08
9/29/15 03:06 PM
Quick Reply: Blown GT's w/450+ rwhp, how y'all holding up?
