Big Brakes and Wheel Combos ....
Thought I would start a new thread that will help others here on deciding which wheel / big brake combo would work. Please include detail wheel
specs and big brake manufacture info - as well as pics !!
If you run Axis Hiro wheels with a 19” x 8.5” (35mm offset) and a 19” x 9.5” (45mm offset) you can run any AP brake kit. The orange Mustang runs a 6 piston up front and a 4 piston out back.
However if you have the factory 18” Fanblades you can run the AP 4-piston kit with the 3mm spacer provided.
http://www.stillen.com/specials.asp
I'm just upgrading to the Baer 14" 2-pc eradispeeds with brackets for the stock calipers up front with better pads and ss lines, and getting drilled 1-pc stock sized rears with black hats and pads/lines in the rear so they match aesthetically, and so it all uses the stock wheels without spacers, and all for well under $1k
I have the stoptech kit up front with Ford GT BBS wheels, and I love the set-up. Stoptech brakes are rebadged for Roush, Saleen, and Steeda, and for the performance to price they are a great deal. If I could do it over again, I would have gone with the GT500 Brembo's with upgraded pads and rotors.
Fitz
Fitz
I am running Wilwood 6 piston 14 inch front and 4 piston 12.5 rear brakes. I have Shelby Razor 18x9 and ZE Forged Boost model 18x9 fronts, 17x10 rear wheels. Both sets clear with out any problems.
Earl
Earl
Stangmods had them but they may be out of stock, they are floating around several sites(just make sure its the set that comes with brackets). The rears I plan on getting will be rotopros. Pads are undecided, probably good old HPS's and some ss lines.
hi. can the 19x10.5" rears fit ok? with the stillen brake upgrade?
also, do the axis hiro need ring kit or is it hub centric?
thanks!
GT500 Brembos with factory 18" polished bullits - need 25mm (1") spacers front and rear.
Details here: http://www.mustang-gtcs.info
