Anyone like aluminum driveshafts?
#62
Regarding Auto Transmissions
Regarding the AUTO TRANS applications: It's a crapshoot regarding vibrations. Ford has 2 part numbers for our driveshafts. They are identical in all ways except 1. The Auto trans driveshaft has built in dampening material to prevent the vibrations. There are a couple of companies looking into this, but who knows when it will be released. The problem is the pinion angle and the output shaft. The vibration is more prominent on cars that are lowered because it changes the pinion angle.
This driveshaft may work on the autos but the pinion angle will most likely have to be adjusted. The range could be anywhere from -1 to -4 degrees. I believe -3 is the optimal for the stock driveshaft configuration, but each car may be different. Ford used the dampening material for the autos because the vibration actually comes from the output shaft of the tranny. The reason the pinion angle may have to be adjusted is due to the fact that the 2 piece driveshaft compensated for it.
I know a few people who have stock suspension that used the PH aluminum driveshafts with no issues, so these may work..... you just cant bet on it.
CR: I'm not trying to hurt potential sales. I'm trying to save you from a big headache if there are issues with the vibrations.
#64
Former Vendor
Oh no, HiRoller, absolutely no problem. That was a great write up, I appreciate the legwork. So basically, with the right installation (adjustment) and some sort of dampening to the tranny output, and it will eliminate the vibration.
Thats good to know!
Thanks for the orders thus far, and we've gotten 2 paid for. Let's try and get three more for that discounted price. These can ship Monday morning.
CR
Tillman Speed
Thats good to know!
CR
Tillman Speed
#65
Former Vendor
I am going to contact them Monday morning and post the questions about:
Vibration (trans output shaft dampening)
Steeda Shifter
GT500 fitment
I will post back Just to ease the job for you guys!
Steeda Shifter
GT500 fitment
#66
AWESOME you guys rock - thanks!!!
(and remember its Saleen short shifter kit)
#67
#68
Or, keep your Saleen adaptor and sell my your driveshaft dirt cheap!
#69
Thanks, my order will be dependent upon the Saleen short throw adaptor issue. I have the adaptor so if it don't fit, sorry.
#71
i'm just wondering if anybody has even tried the 4" shafts with a saleen shifter yet. so far alot of people are saying it doesn't fit but i don't know of anyone specific person thats tried. somebody that has tried please chime in so we can know what and where the clearance issue really is. a 3.5" driveshaft will only gain 1/4" of clearance so i can't imagine those working either if it's that close.
i just measured my old stock shaft and it's 2.78" diameter. which will give about 5/8" clearance over a 4" shaft.
#73
Former Vendor
I am calling Monday confirming the shifter adaptor issue and clearance. I'm not positive that it will have issues. Sure it will be very close.
CFR865 you're all set!
Thanks everyone, I'll get all of these issues smoothed out Monday!!!
CR
Tillman Speed
CR
Tillman Speed
#74
jason,
#75
Just read through all four pages no one has mentioned possible issues with lowered cars. It's been reported that some, not all, lowered cars with an aftermarket 4" driveshaft have had rubbing problems. Some have solved it by massaging the underside tunnel with a hammer. :-) Just seems this could be an issue not discussed yet. I'm looking at at 3" steel driveshaft to avoid this issue. But still undecided.
#76
I'm still waiting to see any truly measured performance gains..... Hey Tillman once you get some of these, since they're so easy to change do a before and after dyno comparison please. Or if anyone has track times before/after that's fine too.
#77
"It works with all mustangs and is a DIRECT bolt-on for those with stock vehicles or standard suspension mods, and VERY little modification (about 5 minutes worth of work) is neccessary on EXTREMELY lowered 3+ inches applications."
#78
guys,
a 4" 1 piece driveshaft will NOT work with the saleen adapter. yes it accepts a stock flange but the flange part is in front of the saleen adapter. the adapter actually hits the driveshaft. the only driveshaft that works with the saleen adapter is the DSS one which i beleive is a 3.5" shaft
Also you will not see a 15hp increase with any driveshaft. some people have dynoed before and after on the driveshaft install. most have seen 2-4hp. its not adding any HP its just freeing it up in rotational mass weight loss.
Another noteable point is if you are lowered you HAVE to adjust your pinion angle. you can do this with an adjustable UCA like the CHE or BMR piece. Non lowered cars can usually get away without adjusting your pinion angle but it will still be off from the correct angle which has been said to be -3 degrees. -3 degrees worked perfectly for me. some have had to goto -2 or -4 degrees. The reason you have to adjust the angle is that the driveshaft will hit the body right before the gas tank and rub against the tunnel on semi hard acceleratinos and launches. also if you have a few heavy people in the car, it will make the driveshaft hit the tunnel on mild acceleration.
and the paragraph about 3+inhes for lowered vehicles is wrong. im only 1.5" lowered and my driveshaft hit the first test drive. the UCA went in 2 days later to correct the problem
#79
guys,
So 3" drive shaft is looking pretty good about now.
