Anyone experience with Steeda's Stop the (Wheel) Hop Pak?
Old Apr 16, 2008 | 12:46 AM
StangRalle's Avatar
Question Anyone experience with Steeda's Stop the (Wheel) Hop Pak?
I am looking into buying this pak as my wheel hop is getting on my nerves.
Anyone here having live expirience with Steeda's 'stop the hop' pak?
Cost: $300.00 plus shipping.
I've read in a recent post, that the FR package is crap and does not stop the hop, so I was wondering about Steeda's. Just don't want to waste money.
Thanks for your input.
Ralph
____
Here a picture:
Old Apr 16, 2008 | 05:47 AM
MTAS's Avatar
No experience with those products, but you might also want to check out www.bmrfabrication.com and see if they have something comparable.
Old Apr 16, 2008 | 06:07 AM
tom281's Avatar
I don't have that "package" but I've had those lower control arms for over a year now (almost 2 years actually) and they eliminated 99% of my wheel hop. I bought them from Brenspeed for like $200 delivered back then.
Old Apr 16, 2008 | 07:31 AM
05YellowGT's Avatar
I don't have that package , but I do have their billet lower control arms and relocation brackets and they definitely helped with the wheel hop. I will probably add the upper 3rd link control arm later ...
Old Apr 16, 2008 | 07:42 AM
blkstang06's Avatar
Heres my stop the hop pak, from J&M... www.hotpart.com They use a spherical bushing design that is patent pending..... the only one with this bushing design....
Old Apr 16, 2008 | 05:24 PM
Superfly SN95's Avatar
Oh no. Now I think this is on the list of mods to do next month thanks Tom!
Old Apr 16, 2008 | 06:38 PM
tom281's Avatar
It's a great, cheap mod if you ask me. Well not that $200 is cheap but you know what I mean hahahaa.
Old Apr 16, 2008 | 07:38 PM
70MACH1OWNER's Avatar
Not trying to be a thread buster here but what is the difference between the manuals and my auto? I have never had a wheel hop moment when I wanted to get frisky. Whether I was at stock HP and stock wheels or my present HP and the Nitto 275's. Hot weather or cold I have never had one hopping moment from my car. And I still have 100% stock suspension. While I cannot dump the power to the rear wheels at 5000 RPM like you guys I am just curious of why?? And this vid is my was just taken this past weekend and I am running my 275 Nitto's. Any explanation??
Scott
http://s138.photobucket.com/albums/q...theMaggies.flv
Old Apr 16, 2008 | 09:24 PM
shaun_beauchamp's Avatar
Many cars don't have a wheel hop issue. My auto vert never had an issue. My 5-spd coupe had only a tad of an issue which was stopped by LCAs, lowering springs, and a Panhard rod. They were all installed together, so I can't say that just the LCAs will do the trick. I know the upper mount and solid lowers is the way to go if you want less NVH. You will also be able to modify the pinion angle and I think that is what really "fixes" the hop.
Old Apr 16, 2008 | 09:40 PM
ryan1112's Avatar
You may want to get the adjustable uca instead of the fixed one so you can adjust pinion angle. You may need to if you lower your car or get a driveshaft. Also if you lower your car you should get the relocations brackets or you will be spinning tires a lot.
Old Apr 16, 2008 | 11:11 PM
2kanchoo's Avatar
I have those exact lower control arms. They completely rid me of all wheel hop. I would also suggest going with the street adjustable upper third link instead tho. If you're gonna bother changing it might as well get one that will allow you to adjust pinion angle.
Old Apr 17, 2008 | 12:23 AM
Personally, wheel hop increased after I lowered the car. That's why I will be looking into an adjustable uca, solid lca's, and relo's. I felt very little wheel hop with 100% stock suspension. I'm using a manual.
Old Apr 17, 2008 | 04:25 PM
StangRalle's Avatar
Same here.
Old Apr 18, 2008 | 12:17 AM
SurfNut's Avatar
Got that...
I have the Steeda pack on my car. Works perfect, just like its suppose to. I'd buy it again if I had to.
tukatz
Aug 13, 2015 09:27 AM
ustabawannab
Aug 5, 2015 08:32 PM
tdf017
Aug 5, 2015 10:13 AM
Jul 30, 2015 06:47 AM
retiredf5
Ecoboost
Jul 21, 2015 05:54 PM
