Aluminum driveshaft
Old Apr 24, 2020 | 02:37 PM
54_white's Avatar
Aluminum driveshaft
I been doing a lot of research and still need advise, what is the best driveshaft for a 06 automatic? I seen the Steeda but it only supports up to 750hp not sure if that’s to crank or RW. Can you guys help
Old Apr 24, 2020 | 05:43 PM
EF1's Avatar
EF1
I have a Steeda 3.5" aluminum in my 2011. It is a quality piece and a good balance between capability and price. I am naturally aspirated so the 750 hp rating is fine for me. If you need a higher horsepower rating look at The Driveshaft Shop or have a local shop build a custom driveshaft for your use.
Old Apr 24, 2020 | 05:47 PM
54_white's Avatar
I hope to get 500 to RW with my v3, and in future do bottom end and shoot for 620 to RW is this shaft gonna work
Old Apr 24, 2020 | 06:09 PM
EF1's Avatar
EF1
It should be fine, I am pretty sure the 750 hp is at the wheels, but you can always check with Steeda to be safe. Good luck with your build.
Old Apr 29, 2020 | 06:07 AM
Bert's Avatar
Shaftmasters also offers a reasonably priced aluminum driveshaft, very similar to the Steeda (might be the exact same thing, not sure) -- something like $600 last time I checked.
For super high HP/Torque numbers you'll need one of the high end carbon fiber shafts, price tag is in the thousands. Pretty sure Driveshaft Shop has them, or Google can find them.
Be aware that some of these shafts (the lower priced ones) use U-joints which are said to have vibration issues due to the driveline angles, if the angles are not set just right. The higher priced ones often use CV (Constant Velocity) joints which are claimed to eliminate the phasing/vibration issues, but have other potential issues such as slop in joints (and potential vibrations due to the slop). If you are going to spend the money it's probably worth investing the time to understand the differences to make an informed choice.
In reply to the original question: I guess one of the carbon fiber shafts with the CV joints is probably the "best"
zbrewha863
Aug 29, 2012 01:10 PM
TMac
18
Jan 6, 2008 06:15 PM
nonsensez9
2007-2009 Shelby GT500
May 28, 2006 08:34 PM
Fman67
Jun 7, 2005 12:01 PM
