5.0 3v with velocity stack EFI
Old Nov 21, 2008 | 06:57 PM
rocky61201's Avatar
Don't know if I'd ever use this setup, even if I had the money, but it sure is different, and friggen kewl.
http://www.techcointl.com/5-0L-3V-Cr...01-b000997.htm
Old Nov 21, 2008 | 08:42 PM
travelers's Avatar
It would be great for a show car.
Old Nov 21, 2008 | 11:42 PM
jaguarking11's Avatar
Velocity stacks are great for high revving engines. So even with stock bore and stroke as long as you run 11:1 and ported heads as well as some custom ground cams caped with some 10,000rpm springs. You could rev the ***** out the engine making around 450hp+ @ 7500-8000rpm.
That would be a wicked setup for a road course as well as basically bullet proof.
Old Nov 22, 2008 | 09:19 AM
Keystone's Avatar
$21,000?!!
Old Nov 22, 2008 | 12:38 PM
70MACH1OWNER's Avatar
Originally Posted by Keystone
$21,000?!!
My thoughts exactly. But it is pretty!!
Old Nov 23, 2008 | 02:58 PM
metroplex's Avatar
The BMW M3's 4.0L V8 (makes 414 hp naturally aspirated) employs a similar intake design. I was impressed that they made it a production motor.
Old Nov 23, 2008 | 10:31 PM
Actualy velocity stacks are a very old design, they were used in the 60's & 50's widely in motorsports. With enough fab skills you can have a nice set of velocity stacks on your 3v engine with a cold air insulated box for less than a grand.
If that engine comes with ported heads and springs, you could be looking at around 550hp with 11:1 @ 302ci and still run on 93octane with the right tune.
That engine looks sick.
Old Nov 24, 2008 | 02:47 AM
metroplex's Avatar
Yes, but velocity stacks are still used in Formula 1 and other modern motor sports.
Old Nov 26, 2008 | 12:22 AM
Yes... the downside to velocity stacks is that it kills low end torque but they work well with high rpm. Reason why F1 engines rev to 19k+
Old Nov 26, 2008 | 02:52 AM
metroplex's Avatar
Yep, and why the BMW M3's 4.0L V8 can rev to 8000+ RPM and make 414 hp naturally aspirated.
Old Nov 29, 2008 | 02:18 AM
Yes, definitely. It makes 420hp as well as 295lb of torque @3900rpm...
Nicely put there.... 0-60 in 4.8seconds, a nearly stock stang can do those 0-60dashes. Not to mention the 22.8mpg estimated, in euro trim.
Old Nov 29, 2008 | 05:19 AM
metroplex's Avatar
Actually the BMW M3 is only slightly lagging behind the C6 Z51 Corvette in 0-60 MPH, 1/4 ET, skidpad, and lane change. It does the 1/4 in something like 12.7 seconds and manages 0.95G on the skidpad. A stock S197 GT won't even come close to those numbers (except 0-60 MPH) especially with its "moderate" understeer. The BMW M3 also has an electronically adjustable suspension, projector Xenon HID headlights, LED exterior lights, carbon fiber roof, universal garage transmitter, and 10+ year corrosion warranty thanks to German engineering. My stock S197 gets 23 MPG in mixed driving (only by doing 15 MPH below the speed limit on our freeways) and many of our aluminum hoods have already started to rust.
The M3's 4.0L V8 makes 414 hp and about as much torque as a stock 96-98 Ford 4.6L 2V V8. Ford's 4.6L 2V made anywhere from 200 hp to 260 hp in stock trim, while the 3V and 4V kick it up to a meager 300-320 hp. My Crown Vic has the same motor as a 96-98 Mustang GT and came with 215 hp / 285 ft-lb, but in reality people got about 190 bhp based on dyno figures. I have yet to see a naturally aspirated streetable and production-quality Ford 4.6L 2/3/4V V8 make 476 hp.
FWIW the BMW 335d Coupe gets 56 MPG and has 284 hp, 16 hp down from the 335i's gas twin-turbo I6 (300 hp) but it has 420+ ft-lb of torque. 0-60 in 6 seconds and puts the Prius to shame with gas mileage. 850+ miles between fill-ups. It's not cheap but that is the personification of balanced engineering.
Old Nov 30, 2008 | 01:41 PM
Bullitt995's Avatar
Go buy a BMW already.
Old Nov 30, 2008 | 07:52 PM
Yay for bmw, it still cost more than a z51 vette. Just FYI. Secondly the german engineering is yet to be proven on the new m3. If its like the new TT 330 bmw, they can keep it. Nothing but problems. Corrosion resistance means nothing when your pistons have holes in them btw.
Your crownvic will also put 500k miles on it with good maintenance FYI. I have yet to see a new m3 put down the kind of numbers a s197 would fully prepped at the track. Secondly your stang is less than 1/2 the price. Dont expect world class performance for 30k. Hell the m3 does not deliver world class performance for more than twice the price.
Now your quoting a diesel engined car that wont pas us emissions. The most fuel efficient cars in Europe btw are fords. The fiesta with its diesel can achieve close to 70mpg. Just an FYI
I have a solution for you however. Sell the crownvic then sell the s197 stang. Save up and take public transport and then buy yourself a nice M3. Maybe your m3 will get schooled by a s197 by then. I am sick and tired of hearing that trash.
Old Dec 3, 2008 | 06:55 AM
metroplex's Avatar
Yes, the ECOnetic Fiesta is rated for 65 MPG. They have ECOnetic Focuses as well. We still have the lousy C170 Focus in the States while everyone in the world gets the C1 Focus (including Taiwan). Subaru has diesels and even the Jaguar XJ twin-turbo gets 53 MPG on the highway. Luxury and fuel economy.
The Crown Vics won't get 500k miles. The 4R70W will fail well before then, even faster when supercharged or bolted to a high torque engine setup. The OD band is the first to go. My Vic gets an abysmal 20 MPG on the highway only by cruising at 55 MPH in a 70 MPH zone (factory rating was 21 MPG) and acts up when it is moist and cold. The Coil packs are brand new.
I checked out the Corvette L4T's around my area and couldn't find many. I called up dealers that were farther away and the prices were competitive with the BMW M3 Coupe. The problem with the Corvette is that you get old-person styling with cheap GM plastic interiors (wrapped with cheap leather on the L4T), but the HUD and F55 magnetic suspension is nice.
Old Dec 3, 2008 | 03:34 PM
travelers's Avatar
I think this is even better.
Old Dec 3, 2008 | 11:13 PM
I know for a fact the crownvic my buddy has, has over 480k on it. It needs a new heatercore and still gets over 20mpg. Its now a retired cab, I even considered getting it off his hands and using it as a winter beater.
Then your comparing a crownvic with forced induction that's not factory and retails for around 25-30k depending on where you get it to a BMW M3?
I should restate my previous statement. You should sell both your cars and move out the country.
FYI
LT4 vettes are C4's z51 package budd, ls6 & ls1 is for z06 c5 & ca5/early c6. C6 is ls2 or ls3 mostly and if driven carefully will net over 30mpg and will smoke a m3 out the box. Z06 now gets a ls7 (427ci btw) gets over 25mpg and has 505hp out the box, with bolt on's on the ls7 you get over 600crank and still get over 25mpg highway. Ls3 with bolt on's gets over 500crank btw. FI ls3 is good for over 600 to the wheels. As for cheep interors, maybe so. But it will put a bigger smile on my face than a m3 all the way to the bank.
Again your comparing apples to oranges. You have to admit you have a problem with ford & anything made here. Sell them both and buy something that tickles your fancy. If the cars you own don't make you happy then you made a misinformed purchase and its your fault not the manufacturers. Do your homework before buying anything.
Old Dec 3, 2008 | 11:15 PM
future9er24's Avatar
that is absolutely gorgeous
Road_Runner
Sep 2, 2024 04:46 PM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
Cdvision
Sep 5, 2015 05:22 PM
