400RWHP N/A is it possible?
I'd love to get my car to 400 rwhp, however haven't seen too many guys get up much over 320 rwhp N/A on the stock motor. Is it possible? Can it be done? What's the highest rwhp you guys have seen from an N/a car? I'm planning on eventually doing heads and cams but how close will that get me? I'm not sure anyone really knows yet. Another question, am I going to spend more money doing all that work to get to 400rwhp N/A than I would sacking up and buy a supercharger?
I wouldn't be surprised if 400 NA is possible with head and cam work. MM&FF just had an interested article about BBR's heads and cams. Although I'm not entirely sure that the numbers are right, it's on my list of possibilities.
Good question. I think the best bet is to get a supercharger. Even on a stock block, $5K in a supercharger can get you 450 at the wheel.
To build a block with overbore, pistons, rods, heads, cams, etc, will probably cost more than that and net less rwhp.
It would be a shame to put over 5K in a NA motor, and have every supercharged and turbocharged car out there walk all over me.
I haven't read of anybody getting crazy hp out of an NA car, though I'm sure somebody has.
Stop talking about nitrous and other F/I he wants to know about NA.
Yeah you could make 400 to the wheels you will need a pretty radical cam and lots of head/intake work though. Could also be done by boring and stroking.
big-bore and/or stroke it, add in head and cam work and you might hit 400rwhp. Those are just the big mods, if you wanted to do a full bolt on...
Short Ram intake ( C&L or JLT, not Granatelli
Diablo or SCT tuners with good custom dyno tuning
Short or Long Tube Headers and X-Pipe
Intake Manifold Control Plate Deletes
Electric Water Pump
yada yada, there are some other things you can do but I dont recommend JR's products for business relations related reasons...
-Dan
Electric Water Pump
-Dan
yes you can hit 400, how much money do you have? If you have the money it can be done, just build the engine up, exhaust and intakes ported and polished, cam, high compression pistons, good rings and rods, high flow fuel and oil pump, new heads, headers, no cats, xpipe, and axle backs, cold air intake, computer reflash,new fuel injectors, you get the picture? Well if you got the money it can be done. cheaply, no, done yes. good luck
High compression, lots of timing, high a:f, and all the other bolt-ons may get close. Who's to say, though, since no one (as far as we know) has tried?
Seems like heads and cams are still new tech...I'd wait a bit to see how they can be optimized and tuned before plopping either on.
IMHO, not very likely.
If you believe the rule-of-thumb that it takes 1.5 CFM of air to produce 1 hp, then you would need to run a VE of 1.0 while turning about 7500 rpm. . . . . Again, not very likely.
The Boss Hog
The Boss Hog
This really isn't something that would be taking place in the immediate future but I'm just curious the possibilities of this motor. Thanks everyone for the input. Sounds like some of the mods I have now have me on a good track to get there if possible. What is the highest RWHP anyone has gotten N/A?
well, take for instance that I make 300hp and 305 ft/lbs @ the rear wheels on a Mustang Dyno with the following mods...
JLT short ram intake and Jet throttle body spacer
Hooker long tube headers
I have not considered underdrive pullies cause I very well may bolt a supercharger up top someday. I have not caught the bug to want to bolt everything on that is available just yet but as I stated before I believe you will at least come close enough to it with everything else currently available without removing things like A/C and P/S.
-Dan
-Dan
Electric Water Pump
-Dan
Electric Water Pump
-Dan
On a more on track note, Blow By Racing seems to be to the most outgoing about having high HP N/A vehicles via cams and head jobs. Although there numbers have been disputed in the past, they found their way into MM&FF. I'd like to see an actual 3rd party verify dyno numbers before dropping that much money though.
Head work and cams, however, after labor time especially can be a big chunk of what you would have spent on a supercharger or turbo setup however.
With that in mind, it is possible but I would go with a FI setup first, then do your engine modifications around the FI. This being that heads and cams can be optimized for FI, but if you have NA purpose heads/cams then you'll just have to redo them down the road if you want to optimize your setup.
Originally Posted by don_w
And how do you know this???? Have you done it? Has anyone done it? And don't say BBR... their BS won't fly with me.
It's going to be difficult to hit 400 N/A and alot of JACK! The other side is driveability. The more HP you have N/A, the less tolerable it is on the street.
