2005 GT problems-do you have these?
My problems so far:
1) Gas tank would not fill - FIXED at Dealer
2) Popping in the front end, slow turns - FIXED at Dealer
3) Bucking w/CEL - Turned out to be an ignition/nisfire issue, FIXED at Dealer
4) Squeeky brakes - Rotors turned etc. . still there.
Other issues:
Window tint being scratched - installed aadhesive backed felt strips to seal and everything is A-ok!
Other issues:
Anyone else have a repeated airbag light issue? My cluster went bad at 1900 miles and now at 6700 the light intermittently flashes and then goes on steady again. There's a service bulletin for replacing the cluster, which was done, but the problem is back again.
Originally posted by 69boss@June 11, 2005, 10:48 AM
I have trouble getting gas to go into the tank. The pump shuts of about 100 times throughout the fueling process.
I have the clunking in the front end and in the rear end, parts are on order from dealer, should be in in 2 days. Also, my trunk lid rubs the top of rear bumper and leaves a mark. The dealer adjusted once and buffed out mark but it is doing it again. I will adress that issue when the parts come in.
i have push pin problems inside and out, also my car would not even turn over TWICE, once when I had the trunk open for a few hours, I had to jump it, and two days ago, I got in and turned the key and NOTHING, tried it two more time, still nothing, tried it one more time and the car started right up?????????
The little plastic doo-dad that goes over the door lock stick-thing on the driver's side door comes off every so often when I close the door. I will eventually get the dealer to order a new one. I am also getting honked at and yelled at by a lot of people... seems they like the car...
I had the No Start thing happen a few weeks ago. I was about to show off the car to a friend, and I pushed in the clutch, hit the key, and....nothing. Tried again a couple times and nothing. Finally it started up and hasen't done it since. I spose it's because of the special key Ford uses. Sometimes the car wont recognise the key and then it wont start.
i have noticed that the clutch must be press all the way down ( practily into the firewall) to start the car sometimes i have the same problem.. i push the clutch down more and have no proble starting after that..
Are you sure the clutch was pressed all the way down? Ive done that a couple of times. Sorry, just noticed the other replies! :bang:
One of the early Mustang owners here on TMS had to have the clutch position sensor or something like that replaced. His avator has a picture of his car on a flatbed. Might be having these problems again.
