20" Shelby Razors - Tire options
Old Aug 27, 2010 | 01:45 PM
mrpro999's Avatar
I just bought a set of 20" Razors 40 offset and I wanted some opinions on tire options. I bought the rims used (with tires), and two of the tires look decent to use for the front tires, which are 255, 35, 20 General UHPs.
Should I go grab a set of the UHPs for the backs as well? I can run 275, 35, 20s for the backs, which is the widest (275) they make in a 35, 20.
Just wanted the experts to chime in on what setup for tires you guys are using on your Razored Stangs. I have read good and bad things about the Generals, but I hate to just toss two good tires.
2008 GT vert, factory suspension
Old Aug 27, 2010 | 02:20 PM
mustangray's Avatar
If you are at stock height and have a 40 offset (20x9) the bigest you can put on is 275/35 with no issues my '06 GT had Eibach sportlines on it and my offset was 24 for the big brake set up and the bigest I could fit without rubbing was a 275/30 all the way around
Old Aug 27, 2010 | 02:23 PM
mrpro999's Avatar
Thanks for the info. I am looking to drop it down with a spring kit, but first I wanted to make sure it fit with stock height.
Old Aug 27, 2010 | 08:51 PM
mustangray's Avatar
Heres a pic of my '06 with 20" Razors and 275/30s on it all the way around
Attached Thumbnails 20" Shelby Razors - Tire options-ray_gonzales_still_small.jpg
Old Aug 27, 2010 | 09:09 PM
Ray Man's Avatar
Wow... those rears didn't scrape?
Old Aug 27, 2010 | 09:26 PM
mustangray's Avatar
Never touched the tires and I hit some good size dips too
Old Aug 28, 2010 | 11:10 AM
mrpro999's Avatar
What about tire selection? Anyone have and advise on which tires to use? I have two good General UHPs, but have read some not too good things about them.
Plus, Im goign to run 255 35 20 up front and 275, 35, 20 in back. Any issues with different sizes I should consider. I have never did different sizes on my other cars I have owned, always kept all four wheels the same.
Thanks,
Mike
Old Aug 28, 2010 | 12:33 PM
mustangray's Avatar
Thanks,
Mike
On my GT500 (it was lowered but not as bad as the '06 GT) I had 255/35/20s all the way around and my favorite tires are Nitto NT05s
Old Aug 28, 2010 | 01:13 PM
Twin Turbo's Avatar
OMG! That is gorgeous
Old Aug 28, 2010 | 02:12 PM
Rjaniz's Avatar
9" 265/35/20 Nitto 555 tires all around. Recommended by Maverick here. No rubbing, quality look. I like'm.
Old Aug 29, 2010 | 11:09 PM
5pointoh's Avatar
You can fit 275/35/20 in the back no problem at stock height or with a 1.5 inch drop like I did on mine. I am running Nitto 555's with 255/35/20 in the front and 275/35/20 in the back. This gives the car a slight staggered stance as the height of the back tire is slightly taller than the front.
Check out www.onlinetires.com. Great prices!
Ecostang
Nov 3, 2022 08:50 PM
Diode Dynamics
Jun 12, 2018 03:26 PM
junkman9096
Aug 3, 2015 10:58 AM
