Winterizing
Winterizing
I am in canada and will be puuting my new stang away for the winter, What prep/maintenance should I do? It will be stored in my garage.
Glenn,
I did the same thing as you last year. I'll be doing it again this year
At the bare minimum;
-make sure the interior and exterior are clean
-disconnect the negative terminal on the battery. Many of us have had the battery fail over the winter if connected for longer than a week
-before you put the car away, put a fuel stabilizer in the tank when its low, then fill it up (use Sta-Bil). Drive the car around a bit so that the chemical is circulated in the system.
-Change the oil in the fall (there is debate on this)
I will post a huge list of other suggestions soon
Attachment 8833 Here is what I did Last year and this.
