Steam Cleaning The Engine?
Old May 15, 2006 | 09:26 AM
Jon_Purdy's Avatar
Has anyone done this? The reason I ask is some detailers have suggested this as an option over spraying chemicals in the engine bay followed by lots of water to rinse.
Jon
Old May 15, 2006 | 11:46 AM
Tiberius1701's Avatar
As Ringo Starr sang .... "No - no - no - no" High pressure water can leach past electrical packing and down into the spark plug wells. This can cause electrical concerns, misfire and coil pack or other component failure. If you do clean the engine bay use something like Simple Green and a low pressure hose.
I have seen too many vehicles that have had their engine bays detailed only to cause problems like the examples I mentioned above.
Old May 15, 2006 | 12:18 PM
Ranger's Avatar
Agree - I read on this site before getting my car about using Simple Green.. I use a 50% solution in a spray bottle and then with a very gentle spray, rinse off. Do cover the computer box, battery, intake and brake reservoir cap. Works great!
Old May 15, 2006 | 09:42 PM
Jon_Purdy's Avatar
Should the plugs (or anything else for that matter) be covered? Ive seen many photos of fabulous looking engine bays but I'm a little leary of spraying anything in there. Not sure what to do.
Jon
Old May 16, 2006 | 09:17 AM
adrenalin's Avatar
wow, you guys sure cover a lot. All I cover is the air filter but now that I put the stock box back in I don't cover anything. I lightly rinse the engine bay and then spray Simple Green full strenght onto everything. I then hose it down. Since I just got my car back from the body shop it was very dirty. I used a power washer but made sure I didn't point it directly at areas like the spark plugs. It cleaned up the brake fluid that leaks from the cap with no issues
Old May 16, 2006 | 10:10 AM
Ranger's Avatar
Jon
I use a shop vac to blow the water that remains from the bay area - it will collect in the plug area but todate - no problems
Old May 16, 2006 | 10:24 AM
OKCMustangGT's Avatar
No couple wraps of teflon tape on the threads to prevent this leak??
Old May 16, 2006 | 12:52 PM
rocket88's Avatar
I don't cover anything either...I just spray it down lightly with the hose and then blow it dry with the blow gun from my air compressor.
Old Aug 30, 2006 | 05:11 PM
codeman94's Avatar
how do you keep the Black plastic shiney and clean?
Old Aug 30, 2006 | 05:13 PM
codeman94's Avatar
never mind....found it.....tire shine!
Old Aug 31, 2006 | 06:00 AM
flashfearless's Avatar
I would recommend 303...
Road_Runner
Sep 2, 2024 04:46 PM
trackpack13gt
Oct 2, 2015 08:20 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
