Rogue window adhesive
Old Mar 14, 2008 | 08:07 PM
EastCoast07GtCs's Avatar
Installed a set of flush-mount louvers today, and some of the adhesive squished out from behind as i was setting them in place.
Anyone know what I can use to remove the excess??
Old Mar 14, 2008 | 08:11 PM
05GT-O.C.D.'s Avatar
I lust for a M24
You really should've gotten that out immediately. If it's in the crack, you're going to need to scrape it out... which I don't recommend. Maybe now would be a time to consider the Scott Drake quarter window trim.
Old Mar 14, 2008 | 08:15 PM
My bad, it's not the actual adhesive, but the promotor haze that is a showing a bit on the edges. Can that stuff be cleaned? It's not part of the actually adhesion area.
Old Mar 14, 2008 | 09:24 PM
kh765's Avatar
Try a bug and tar remover and see if that works.
Old Mar 15, 2008 | 06:48 PM
citizen arcane's Avatar
Goo Gone
Old Mar 15, 2008 | 06:56 PM
Do any of these work on contact or do they all require rubbing? Problem is the area is quite small metween the opening and the louvers.
Old Mar 15, 2008 | 10:42 PM
kh765's Avatar
Bug and tar removers should work on contact. Very little agitation needed.
Old Mar 19, 2008 | 01:26 PM
adrenalin's Avatar
You will have to do some sort of "rubbing". These products just penetrate the adhesive. You still need to use a little bit of elbow grease to lift the adhesive off of the surface.
Old Mar 19, 2008 | 06:32 PM
That's what I figured. Question now is what do I use to get in that small area...
Old Mar 19, 2008 | 06:52 PM
officespace56's Avatar
Q-tip?
Old Mar 19, 2008 | 07:03 PM
+1 Q-Tip.
Remember not to stick it in your ear too far, you'll scratch your brain.
Old Mar 19, 2008 | 07:23 PM
Yea, tried the q-tip, not strong enough Oh, and my brain itches????
Old Mar 19, 2008 | 07:25 PM
codeman94's Avatar
toothpick?
Old Mar 20, 2008 | 06:36 AM
adrenalin's Avatar
Can you get at it with a flat piece of plastic (ie: credit card)? That is what I normally use for those hard to reach areas.
Old Mar 20, 2008 | 08:48 AM
Yeah thats a good idea. Use a thin plastic object like a credit card or plastic spatula and cover it with a rag and then wedge it in there and rub. I've used that before.
Old Mar 20, 2008 | 05:50 PM
That's what I was thinking, something plastic. I think I remember seeing TacoBill using something that looked almost like a large pink plastic skewer with an edge in one of his writeups. Almost like a thin plastic chisel? Thanks for all the advice, gonna try a bit if all of them I guess until I find one that works
BTW: CC is a great idea, considering how much I am spending on the car they should be useless soon anyway.....
Old Mar 22, 2008 | 11:05 PM
JedCranium's Avatar
Before you do anything I would call the company that makes that stuff and see what they recommend to remove/neutralize it. I know your in a hurry to fix it but how many times have we rush something thinking it would work only to make it worse than it was.
Jed
Old Mar 24, 2008 | 04:07 AM
^ Ahhhh, the voice of reason.
Thanks Jed, took your advice and did exactly that. I emailed 3M and asked for a recommendation on removing their promotor. My only concern is they will have the answer, but will say it will remove the promotor AND the paint....
We'll see what they come up with.
Old Mar 24, 2008 | 10:31 PM
kh765's Avatar
They'll probably tell you to use 3M adhesive remover.
Old Mar 26, 2008 | 06:28 PM
Pfft... exactly what they did, including the part number.
# 08984 for anyone interested.
Uofmrampage
Aug 2, 2022 02:55 PM
iliveonnitro
Oct 7, 2021 06:31 PM
kponypower
Jun 17, 2020 07:17 AM
CoyotePremium13
Sep 23, 2015 06:45 PM
