Over spray
Old Aug 7, 2005 | 09:30 PM
wild stray's Avatar
In my travels, I've picked up a mist of white paint (water base) on my car from someone painting a building in the area. The mist is actually so fine that it can't be seen unless the car is in a certain light, but then it shows up very clear.
Anyone have success with a product for this?
Thanx,
Paul
Old Aug 8, 2005 | 12:45 AM
StangNut's Avatar
I had the same problem with my black '03. The ONLY thing that would get it off my car was a clay bar.
Old Aug 8, 2005 | 09:23 AM
harrier's Avatar
yes, clay bar it.
http://nino.dnsalias.org/carwash/
Old Aug 8, 2005 | 10:29 AM
wild stray's Avatar
Thank you! I'll give it a try.
Paul
Old Aug 18, 2005 | 11:55 AM
adrenalin's Avatar
If clay bar does not work you need to wet sand the area using 2000 grit paper. Then use a fine polish, wax and away you go. I had the same thing happen to me years ago. What a pain.
Old Aug 18, 2005 | 07:38 PM
wild stray's Avatar
Thanx John;
The clay bar works if you clay a very small area three or four times. :notnice: You know, an area the size of a tennis ball!
I ordered a paint cleaner/swirl remover from Zaino and I am hoping it will take care of the problem. I actually thought of using the swirl remover with a little hot water, since I know the paint spray is water base. Otherwise, I'll give the 2000 paper a try.
Paul
Jim74656
May 1, 2023 02:15 AM
FromZto5
Oct 2, 2015 10:07 AM
FromZto5
Aug 24, 2015 09:02 AM
mark0006
Aug 7, 2015 10:32 PM
05STG1
30
Oct 16, 2005 12:11 AM
