Mr. Clean Autodry
I love it. It works by using filtered water to rinse the car so minerals (a major cause of water spots) are removed from the water and thus not left behind on your paint's surface. I still dry by hand to ensure I get zero water spots. You might as well use it for your mustang as well, you still have to wash it by hand the mr. clean just holds soap and the filter. You still need to "scrub" the car's surface.
I guess I'll have to try it then. Are they expensive or relatively cheap. Walmart would have it right?
I've been using eagle one car wash (stuffs pretty good right?) and a tanners select chamois to dry. We have really hard water around here.
I also use nu finish wax which I've been using since I first learned to wax a car.
Thanks for the feedback guys!
Originally posted by Badandy@April 12, 2005, 9:28 AM
mr clean autodry will work, but get rid of the nufinish! this is a mustang, not a beater car.
I thought nu finish was good. i've never had a problem with it. Granted it doesn't last a year like it advertises but it seems to work for me. What would you suggest, I'm always willing to try a new product?
Glad you asked
There are many products which will make your finish look much better.
I would recommend Meguiars 3-step process for you. That can be found on Meguiars.com or you can ask them more questions on meguiarsonline.com
If you want a one step process, Meguiars NXT Tech Wax is a great one step process. Ask more questions if you have any!
Originally posted by Badandy@April 14, 2005, 4:02 PM
Glad you asked
Glad you asked
