Local tire shop gouged my painted rims
Can anything be done to improve the looks? Hubby doesn't want the hassle, just won't use them again. The rim is pretty beat up in about 3 places. Went in to have a flat fixed,wasn't even on the car,I had it in the truck bed. I'm sick.
This is how sick I am-Rims are 17" bright machine cast aluminum,not painted.
Called dealer-new rim is $252.60 with my rim turned in, $302.60 if I keep old rim. Recommended Tire and Wheel Connection of Houston for repair. They said they fix 25-30 each day, and it would be $125.00 to repair. Ouch all the way around.
Do I understand it that a tire shop damaged one of your rims while fixing a flat? Well if that is the case, I would talk to the manager of that shop and show him the rim and tell him that they have to buy you a replacement. All reputable auto shops have insurance that covers things like this. Why should you have to buy a new rim if they damaged it????
When I had new tires put on my Accord each wheel was damaged when some ape used a pair of pump pliers to remove the valve stems instead of the right tool. Gouged each alloy wheel. I went back inside a grabbed the manager, took him outside and pointed out the damage and told him I knew they screwed up. He said he would call me when my new wheels came in, and they did.
You have to go back and talk to a manager or owner, the squeaky wheel gets the grease.
It's not a friends tire shop I hope ? then if they did it and it was not done in the back of the pick up , did you notice right then and there ? or was it after ? you may have to use those words wisley at that point to try to get them to acceptance. Worse case I buy Shelby rims and sell off mine or give you one Cheryl
Rereading original post,it doesn't make sense-Hubby removed tire,put it in truck bed. I drove it to the shop, they removed it, fixed flat, put it back in truck, I paid the bill, drove home.
Well if I do order a set of Shelby wheels I will post my Premium machine cast here somewhere, and now were getting seven Shebly's here all spoken for and those on the list too late were all called sorry not enough, I'm in the sorry factor.Hope it all works out for you.
Life really is a daily learning quest Huh !
As I said before, if they damaged it, they should pay for a replacment. One thing I always do when I leave my cars for some kind of service, I always walk around my car and inspect it for any damage before leaving the shop. Especially around the area where they worked on it. I even do this when I take it to my dealer for an oil change. But thats just me I guess. Hope they take care of it for you. If you are sure they did it, I would demand that they replace the damaged part. Tell them it is not acceptable.
Have never had anything bad happen, but I'm a paranoid.
With the stang, I've gotten so bad that I take a walk around video before I leave it with service.
