Cleaning bird poo from vinyl stripes?
I love my new BSM 12" vinyl stripes! And so do the birds.
I just noticed some bird poo on the hood stripe today. There is no way it was there for more than 12 hours, but now the vinyl is stained. I've tried washing with soap and water. Also tried goo gone with no luck.
How do you all keep your stripes pearly white?
Jeramie
Jeramie
You should alway use baking soda to neutralize the bird droppings acid before you try to wash it 1 teaspoon baking soda to a qt of water. Dab on with a rag and let it soak for a few minutes. This is for all finishes not just the vinyl. Trying to scrub it off will scratchthe paint because birds also ingest small grains of rock/sand when they eat to help their digestive sytem clean itself. NO POO!!!!
good luck
07 Hoss
good luck
07 Hoss
or just maybe have this put in place ?
http://vids.myspace.com/index.cfm?fu...eoid=851583497
Wax works pretty well although the poo is acidic so after a time and depending what it ate it may burn in if left too long.
sorry I read Larry's advice after Most Excellent ! I may add.
good luck
07 Hoss
good luck
07 Hoss
I'll definately be putting a wax on the stripes. However, I just installed the stripes TWO weeks ago,, so I have two more weeks before I can wax them. At least according to the directions I got from Baltimore Street Mods.
Try the vinyl/convertible cleaner and then use the protectant. Used it on mine to get wax residue off and it worked great
http://www.properautocare.com/303.ht...FRBGGAodGEf-2A
hate to burst your bubble but the fact is once vinyl becomes stained (especially white) the stain is almost next to impossible to completely remove. If you didn't wax your stripes before you will definately want to now. You might also want to put a coat of glaze on before you wax, as glaze helps repel bird crap, tree sap and UV rays.
The answer: BON AMI. I just tried it and it works. Its like comet but does not scratch.
How I found out: Today I washed the car in preparation for some Zaino. I used dawn dishwashing liquid to remove the old carnuba wax. I have the Zaino clay bar to remove anything left after the wash like bug stains and road tar. Then I noticed my vinyl white stripes. There is what looks like reverse water spots on the stripes. ie. The stripes are white in circles and is greyish black everywhere else on the stripe. The car is almost 1 year old since the car was build. I bought it Dec. 24th. It has not been warm very long, so I waited to wax it until now. I did wash it every two week even in the winter time. So, I tried to remove the black from the stripes, its like a film covering the entire stripe. 1st clay to no avail, 2nd Windex brand surface cleaner with Vinegar with NO ammonia to no avail, 3rd I tried Zaino plastic cleaner to no avail, 4th Baking soda and water to no avail, then I tried lastly Goon Gone in a spray bottle, orange in color, still none of the black is being removed from the stripes. Well, I might have found the right cleaner; Bon Ami.
Jeramie
