need some help
Old Mar 29, 2019 | 06:11 AM
Miguel Figueroa's Avatar
Unhappy need some help
i have a 1995 4.6ltr mustang gt recently replace the solenoid canister
i removed the battery cable to do this job after placing the part tried to start is
then it shuts down seconds later any advice
Old Mar 29, 2019 | 07:38 AM
bad alternator? Check the charging system would be my GUESS
Old Apr 6, 2019 | 11:49 PM
Lime GT's Avatar
Automatic or manual transmission? What was the original problem to make you want to change the starter solenoid?
Old Apr 7, 2019 | 06:25 AM
Mustang
Automátic
scanner gave a 1443 code
Old Apr 12, 2019 | 11:33 PM
Lime GT's Avatar
Did you make sure you installed the solenoid hose connections in the proper direction. The plastic tube closest to the solenoid body should have the charcoal canister hose on it. Also make sure all of the vacuum hoses are in good shape.
Old Apr 13, 2019 | 05:14 AM
mustang
The he check engine came on so I scanned it and gave me a code 1440 I checked at the internet and the recommendation was to replace the solenoid I will check the position I installed it and get back to you
thanks for the reply
Old Apr 14, 2019 | 11:33 AM
Mustang
Every thing is connected right
puma1552
Apr 23, 2014 12:41 PM
DynamiteBlues
05-09 Exterior Modifications
Oct 14, 2009 11:36 AM
98Stanger
Rocket City Mustang Club
Jul 29, 2007 03:04 PM
05MustangFanII
Jul 18, 2006 07:00 PM
Redbaron93
Toys and Automobilia
Mar 1, 2006 11:22 AM
