need some help
i have a 1995 4.6ltr mustang gt recently replace the solenoid canister
i removed the battery cable to do this job after placing the part tried to start is then it shuts down seconds later any advice |
bad alternator? Check the charging system would be my GUESS
Automatic or manual transmission? What was the original problem to make you want to change the starter solenoid?
Mustang
Originally Posted by Lime GT
(Post 7040250)
scanner gave a 1443 code |
Did you make sure you installed the solenoid hose connections in the proper direction. The plastic tube closest to the solenoid body should have the charcoal canister hose on it. Also make sure all of the vacuum hoses are in good shape.
mustang
(Post 7040250)
thanks for the reply |
Mustang
(Post 7040448)
