loosening rusted nuts
Just wondering if it would be OK to heat up a nut with a propane torch and then spray some PB Blaster on it to help loosen it?? Or is that going to cause a little problem?
Swamp Donkey Man Cans
Nope the blue wrench always works well. Just make sure you can't light anything on fire and you have an extinguisher close by, keep in mind that the PB is very flammable. So try it first and give it plenty of time to work. Then if thats is not working dry off the area of any excess PB to reduce the chance of catching fire.
Anyone else who can share any experiences using a propane torch and penetrants/lubricants for loosening rusted bolts??
Like Father...
I ♥ Sausage
I ♥ Sausage
Unless it's red hot when you spray it on (and you don't want to get it that hot anyway), you're not going to start a fire with the PB. Hell, pour some water on it to make sure its cooled down before you spray it if you are worried about a fire.
Can anyone else confirm this? It is just 07S197 was scaring me with his previous post here
If you hit it with spray first and let it soak, even up to 30 min and then if that does not work wipe off any excess spray and try the torch. The torch will burn anything left off and not start any more of a fire than what is already coming out of the torch.
2/10/17 07:12 PM
