loosening rusted nuts
Old Oct 17, 2010 | 06:37 PM
5pointoh's Avatar
Just wondering if it would be OK to heat up a nut with a propane torch and then spray some PB Blaster on it to help loosen it?? Or is that going to cause a little problem?
Old Oct 17, 2010 | 06:41 PM
07S197's Avatar
Swamp Donkey Man Cans
Nope the blue wrench always works well. Just make sure you can't light anything on fire and you have an extinguisher close by, keep in mind that the PB is very flammable. So try it first and give it plenty of time to work. Then if thats is not working dry off the area of any excess PB to reduce the chance of catching fire.
Old Oct 17, 2010 | 07:11 PM
5pointoh's Avatar
I have got the liquid wrench which is NOT flammable....so I may try that first!
Anyone else who can share any experiences using a propane torch and penetrants/lubricants for loosening rusted bolts??
Old Oct 17, 2010 | 07:18 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
I like to heat it, then let it cool a couple of times, then hit it with the PB blaster to soak a few minutes.
Old Oct 17, 2010 | 07:55 PM
What ever you do don't ask Blue Notch, he has to pay people to get his huts off.
Old Oct 17, 2010 | 07:57 PM
07S197's Avatar
No kiddin and then even at that it takes days for him to get them off.
Old Oct 17, 2010 | 10:45 PM
5pointoh's Avatar
So you wait before using the PB Blaster?? I am afraid of starting up a little fire by using it after heating the nut with the propane torch.
Old Oct 18, 2010 | 01:50 AM
Like Father...
I ♥ Sausage
Unless it's red hot when you spray it on (and you don't want to get it that hot anyway), you're not going to start a fire with the PB. Hell, pour some water on it to make sure its cooled down before you spray it if you are worried about a fire.
Old Oct 20, 2010 | 06:22 PM
5pointoh's Avatar
Can anyone else confirm this? It is just 07S197 was scaring me with his previous post here
Old Oct 21, 2010 | 05:40 AM
usally it will take an open flame to start that stuff up. Just use the heat no spray then try to loosen your nuts.
Old Oct 21, 2010 | 08:03 AM
07S197's Avatar
Sorry, not trying to scare you. The car is not going to burst into flames or anything. Just wanted to make sure that you are mindful of the open flame and the fact that some rust busting sprays are flammable. I would hate for anyone to soak down a nut and bolt and then after 30 sec hit it with a torch and start a fire.
If you hit it with spray first and let it soak, even up to 30 min and then if that does not work wipe off any excess spray and try the torch. The torch will burn anything left off and not start any more of a fire than what is already coming out of the torch.
Old Oct 24, 2010 | 04:03 AM
5pointoh's Avatar
Just bought some Moovit today.....has anyone tried this product?
Old Oct 25, 2010 | 01:25 AM
Like Father...
I ♥ Sausage
Never heard of it. I prefer a heat wrench and some PB.
Jim74656
May 1, 2023 02:15 AM
Feb 10, 2017 07:12 PM
JonsMustang
Mar 5, 2016 05:44 PM
bones302
Oct 7, 2015 04:42 AM
Linkspure
Sep 12, 2015 06:33 PM
