Key fob not working after changing car battery
Remote key fob for my 2012 Mustang stopped working after a replacing dead car battery. Both remote key fobs don't work. I've tried replacing the fob battery and the reprogramming fob sequence. Nothing works.......
Anyone have anything similar happen? I can't figure out which fuse would be linked with the remote key fob receiver ...
__________________
__________________
If the batteries have those little lines in them I've had trouble with those at times. Also, take the FOB apart, and pull the connectors up a bit for better connection, maybe scuff them up a bit with some fine sandpaper. If that doesn't work, and I'm not sure there is one, but it could a blown fuse. Since neither one works I'm leaning toward a fuse. Good luck.
finsssss (8/7/17)
Fob
they should never change unless you tried to reprogram or battery died or in backwards. Worse case someone swapped it it for some reason. I've redone my keys & fobs a few times
