Key fob not working after changing car battery
Remote key fob for my 2012 Mustang stopped working after a replacing dead car battery. Both remote key fobs don't work. I've tried replacing the fob battery and the reprogramming fob sequence. Nothing works.......
Anyone have anything similar happen? I can't figure out which fuse would be linked with the remote key fob receiver ... __________________ |
If the batteries have those little lines in them I've had trouble with those at times. Also, take the FOB apart, and pull the connectors up a bit for better connection, maybe scuff them up a bit with some fine sandpaper. If that doesn't work, and I'm not sure there is one, but it could a blown fuse. Since neither one works I'm leaning toward a fuse. Good luck.
Originally Posted by wanted33
(Post 7018691)
Originally Posted by finsssss
(Post 7018711)
wanted33- thanks for your response. No luck with your fob suggestions, but it's another what-about-this to check off the list.
Fob
(Post 7018711)
