Key fob not working after changing car battery
Old Aug 5, 2017 | 09:10 PM
finsssss's Avatar
Remote key fob for my 2012 Mustang stopped working after a replacing dead car battery. Both remote key fobs don't work. I've tried replacing the fob battery and the reprogramming fob sequence. Nothing works.......
Anyone have anything similar happen? I can't figure out which fuse would be linked with the remote key fob receiver ...
__________________
Old Aug 6, 2017 | 12:15 PM
wanted33's Avatar
If the batteries have those little lines in them I've had trouble with those at times. Also, take the FOB apart, and pull the connectors up a bit for better connection, maybe scuff them up a bit with some fine sandpaper. If that doesn't work, and I'm not sure there is one, but it could a blown fuse. Since neither one works I'm leaning toward a fuse. Good luck.
Old Aug 6, 2017 | 10:04 PM
finsssss's Avatar
wanted33- thanks for your response. No luck with your fob suggestions, but it's another what-about-this to check off the list.
Old Aug 7, 2017 | 09:59 AM
wanted33's Avatar
I understand my friend. Like you I would have to do the "well it ain't that" method, then guess again.
Old Oct 6, 2017 | 02:47 AM
GottaHaveIt's Avatar
Fob
they should never change unless you tried to reprogram or battery died or in backwards. Worse case someone swapped it it for some reason. I've redone my keys & fobs a few times
