I Made A Big Boo-Boo
Old Jun 3, 2005 | 04:06 PM
MaverickMLFD371's Avatar
Question
Was installing the K&N Aircharger after I got off work. I had to remove 2 of the valve cover bolts to put on the holding bracket for in the intake, as I bolting the back in the bolts, I over tightened the one bolt and the bolt snapped. Called my dealer, my sales guy, told him what happened and he said just bring it in and we will see what we can do, he would have to drill a small hole in the bit and get it out with some type of tool. Is this gonna be an expensive repair???? Anyone??? God this just made my day and Im sooo upset right now.....
Old Jun 3, 2005 | 04:11 PM
Snets's Avatar
I think it's really going to depend on whether that can extract the bolt without removing the valve cover. Time is $ and R&R of the valve cover is more time. As far as getting the bolt out, should be no problem. Good mechanics get good at thise things.
Buy yourself a torque wrench
Old Jun 3, 2005 | 04:17 PM
flight96's Avatar
Don't worry its no big deal. They will drill a hole in the broken bolt and us an "Easy-out" to get the piece out. Then ya just replace the bolt. Very simple job....Ive do a million of them on old manifold bolts
Old Jun 3, 2005 | 04:19 PM
its in the very front of the valve cover, its easy to get to and a piece of the bolt is sticking out, i mean if I had a pair of good tweezers I could probably twist it out but I know I'll probably break the tweezers too, its seems simple, I just don't want it to be expensive and have to replace a whole piece of the engine cause of a bolt
Old Jun 3, 2005 | 04:20 PM
how much of a job would it be? price wise??
Old Jun 3, 2005 | 04:37 PM
GoHeels's Avatar
Probably get charged an hours labor and the price of the bolt to get it done. Or, go to a hardware shop and buy an "Easy-out" mentioned previously. It looks like a cone shaped drill bit that you run in reverse. As it bites into the metal, it will loosen the bolt. You usually have to predrill a hole to get it started. Really easy to do.
flight96's Avatar
It should be cheap. Especially if its easy to get at....1/2 hour job...hour at most. heck I can easy-out a bolt in 5 min. on my 67 coupe....believe me...Ive done it many times !!! :scratch:
Old Jun 3, 2005 | 04:39 PM
The Lyin' King's Avatar
IMO . . . If all goes well it shouldn't take more than 1/2 hour. A one hour shop charge would be the max I'd expect to pay for something as simple as this.
Old Jun 3, 2005 | 04:40 PM
cop on my back's Avatar
Ken, I didn't know you were a machinist?
Old Jun 3, 2005 | 04:42 PM
flight96's Avatar
I do it all !!
When ya have your own shop ya gottta do it all. Nobody there to do it for ya!!!
Old Jun 3, 2005 | 05:07 PM
Mustang69-05's Avatar
If part of the bolt is still visible, pull the valve cover and use a set of vice grips and take it out. Pretty easy. If enough is sticking up above the valve cover you don't have to take it off.
Old Jun 3, 2005 | 09:10 PM
ITS OUT!!!! Went to the firehouse and my Deputy Chief, who is one heck of a mechanic. Had an easy out! Drilled a hole, put the easy out in, 1/4 turn later, the bolt is out! Sweet!!!! Thanks Guys for the info, really appreciate it!!
May 3, 2026 05:42 AM
kponypower
Jun 17, 2020 07:17 AM
wallace
Mar 29, 2016 10:09 AM
trackpack13gt
Oct 2, 2015 08:20 PM
