How long should water pump last?
Just curious. I think my water pump is squealing and causing me to lose my mind. I'm not sure but when I start my car it's like it will squeal until my car warms up. sometimes it takes even longer.
if you can get a long screw driver or piece or wooden doll pin/toliet plunger handle and stick the big end up to your ear and poke around in there touching the different things wile the engine is running you should be able to narrow it down the the bad part. of course be carefull not to touch any moving belts or pillies <------ just had to say it
Sounds more like power steering.
I agree that usually water pumps leak before failing.
