Fueling issue
Old Jan 27, 2013 | 08:06 PM
mikeship911's Avatar
Fueling issue
When at the pump. My '06 fills around half way and kicks off. Then it clicks off immediately every time I squeeze the handle. Any ideas why this happens?
Old Jan 28, 2013 | 06:11 AM
05GTJOSH's Avatar
This happens sometimes to my 05 gt. I think it's the gas stations issue. I think that the gas is flowing too fast, so it backs up and thinks that your tank is full. I go to a different station an it doesn't happen
Old Jan 28, 2013 | 10:30 AM
05GT4.6's Avatar
Happens to me all the time, boy do I get so freaking mad. I will be on empty and I put a dollar in and it cuts off. You just have to find the sweet spot to keep filling. Even if you look down right retarded when your fueling.
Old Jan 28, 2013 | 12:05 PM
stupidgenius36's Avatar
Just Plain Rude!
It's a known issue. There's been a TSB for it since forever. It helped, but it still happens from time to time. Just depends on the pump, and not necessarily the whole station.
You can also try turning the handle. People will think you're weird, but it helps...
Old Jan 28, 2013 | 05:38 PM
012stang's Avatar
happens to me as well! What i do to stop that is if you pull the nozel out half way and continue fueling it wont stop. It has to do with pump pressure and flow into your inlet pipe to your tank if you push nozel in to far it gets to much fumes and back pressure making pump think your full! it happens to best of us. Doesnt mean somethings wrong with your car its fine lol!
Old Jan 28, 2013 | 06:07 PM
03DJ's Avatar
It has to do with the amount of fumes or gas thats going in. I have that trouble all the time. Just turn the nozzle or something.
Old Jan 29, 2013 | 05:41 PM
BRADGTCS's Avatar
People this is a common problem with many vehicles. simply slow the flow.
Old Jan 31, 2013 | 12:00 AM
Thanks folks. I've done all those and the last time nothing worked. I was there for 10 minutes at .2 gallons at a time. At least I'm not crazy or my cars jacked up.
Old Jan 31, 2013 | 11:15 AM
Just Plain Rude!
If mine gets picky, it'll at least get to half a tank first. So if I really *have to* fill up, I'll just pick a different pump and try again.
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Mrmiles1369
Sep 11, 2015 07:23 PM
