different ignition and trunk keys
Old Jun 27, 2006 | 06:58 PM
MY05GT's Avatar
When I purchased my 95 Cobra used, it came with seperate keys for the ignition and trunk. I am assuming that this is not how it was stock and that the trunk had been changed since the doors match the ignition. Can the trunk tumbler pins be changed to match the rest of the car?
Old Jun 27, 2006 | 08:53 PM
TJ4Cam's Avatar
My Aspire was that way when I bought it (used) the lady had broken a key off in the ignition and the lock was changed...prob happened in your case as well.
Old Jun 28, 2006 | 05:43 AM
Tiberius1701's Avatar
You should be able to buy a trunk lock kit that has all the tumblers you need to match your door/ignition key. You will need to measure the key cuts and build the lock as the instructions describe. Check with Kevin Casey at Clevenger (05stangkc), he may be able to help.
Old Jun 28, 2006 | 11:00 AM
future9er24's Avatar
thats nothing lol. when i bough my car i had seperate keys for the ignition, trucnk, doors and gas cap
sorry, i had to put that lil tidbit in
Old Jun 28, 2006 | 02:15 PM
MY05GT's Avatar
I did not add the gas cap key which I have also
Old Jun 28, 2006 | 02:29 PM
05stangkc's Avatar
Sent Email
kc
Old Jul 7, 2006 | 05:27 PM
codeman94's Avatar
I have the same problem on the '65...different keys for ignition, door, and trunk... any help kc?
Old Sep 7, 2006 | 08:44 PM
MY05GT's Avatar
Found the perfect solution on ebay. I was going to go with KC ( very helpful ) and get a new lockset, but before I could act, a whole lockset showed up on ebay, the kicker is that the lockset is for the antitheft for which the car is pre-wired. Now I am trying to get a compatible anti-theft module to run it. http://forums.bradbarnett.net/showthread.php?t=52330
tang65c
Oct 6, 2015 07:39 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
TMDM
Sep 24, 2015 07:00 PM
BigHoss
Sep 21, 2015 10:03 AM
Sep 8, 2015 10:45 AM
