blower motor
blower motor
i have a 07 gt mustang n i put a resister plug in it and it work on all 4 speeds n then it stop working on all but high now i really don t know what to do
i really thank yall for ur help
The next thing also would be to get a wiring diagram to test the plug. you would test it with the key on, resistor unplugged. move the switch to low there should be battery power, then move the fan switch to next setting and check the next wire for battery power and so on.If the signal is sent and the relay and remaining wiring is working correctly, the blower motor will work. Assuming of course that the motor itself is good and the is a proper ground at the black wire, terminal "A" of the blower motor connector.
