Signal lights (Relay or fuses)
![Post](https://themustangsource.com/forums/images/icons/icon1.gif)
Good Morning.
I just got a 2006 mustang coupe in Windveil blue.
So when i start the car the signal works great but after 10-15 mins the indicator signal stops making the clicking noise in the cabin.
I got some new fuses and a signal relay but i am struggling to find which relay is the one that controls the indicators.
Could anyone let me know which relay i swap out for the indicators and where it is located.
Thank you in advance.
Just parked the car for the winter as i do not want to run it in -40 got to love Winnipeg winters.
The Analog Admin!
Received 2,992 Likes
Welcome!
I'm Attaching Some Pdf's So You Can Get an Idea of How The Signals Are Controlled. The SJB or Smart Junction Box Controls it and My Guess is You Are Getting Moisture to the Box and You Should Inspect & Clean All Connections. Moisture in this area is Common and Usually Due to the Drains in The Cowl Section By the Cabin Filter Being Plugged Up.!
Anyhoo, That is My Shoot From The Hip Answer!
I bet a Lot More Info than You Wanted!
Take a Look at the Water Pdf First and Check Your Drains! If They are Plugged I Would Highly Suspect SJB Has Moisture as well!
When You Get a Chance Post Some Pics of Your Stang!
Cheers!
KC
Cheers!
KC
