Mustang electrical gremnlin
Old May 9, 2019 | 05:11 PM
fixit0828's Avatar
I have a 1969 mustang conv. Bought it new. Just rebuilt the 302 V8 2 bbl. all of a sudden I have no brake lights, turn signals, radio. Head lights and horn work. I’ve changed all the fuses. What’s the problem? Jeff
Old May 9, 2019 | 06:16 PM
SpectreH's Avatar
I’d check the connections of any main wiring harness connections for corrosion.
Old May 9, 2019 | 06:42 PM
fixit0828's Avatar
Elec gremlin
Ok..but which connectors? I did put in a new battery. Could that have fried something?
Old May 9, 2019 | 06:59 PM
SpectreH's Avatar
It's hard to say which connectors. But I bet one is loose or corroded somewhere. Hopefully someone with experience on a classic Mustang will chime in. My classic experience is with Corvairs, not Mustangs.
Old May 12, 2019 | 09:47 AM
Poco's Avatar
check the connection at the fire wall.
Old May 23, 2019 | 07:03 PM
Poco's Avatar
Did you detail the engine bay before you reinstalled your engine? If so and if you painted anything in the engine bay maybe when you reconnected your ground wires the paint will keep from making a metal to metal connection. Scuff with some sand paper around the hole and should have a better connection. ( i have done that with several of my resto projects).
rickey7575
Aug 21, 2015 11:40 PM
ScottieTwoHottie
Mar 21, 2014 06:19 AM
jlareaux
Aug 9, 2012 06:27 PM
jlareaux
Aug 9, 2012 05:06 PM
