Rear drum replacement 2000 dodge grand caravan
Old Jan 2, 2009 | 10:24 AM
Ballz's Avatar
Is this a difficult task? I need to do it to pass inspection. Just drums and not the pads.
Old Jan 2, 2009 | 10:54 AM
frdtch05gt's Avatar
That should be fairly simple, as long as the drums come loose from the hub easily. Sometimes it is necessary to knock the drums loose with a 3-pound hammer if they are really stuck. Also, there might be a few clips on the wheel studs that are used to hold the drum in place at the factory, those clips can be cut off and tossed, they aren't needed.
Old Jan 2, 2009 | 02:04 PM
Vermillion06's Avatar
Also, for drums you may need to back off (loosen) the self adjusters on the shoes because the shoe lining will get stuck on the grooves worn in the drum surface.
Old Jan 2, 2009 | 03:53 PM
Ballz's Avatar
re:
Thanks guys! I didn't think it was beyond my novice knowledge.
Old Jan 5, 2009 | 02:01 PM
97svtgoin05gt's Avatar
Drums without shoes huh??
Old Jan 5, 2009 | 03:36 PM
karman's Avatar
Has me wondering too.
What's the story behind the story?
In other words, why not the shoes too?
I find that it is better to put new shoes with new drums.
While I admit to sometimes just putting new shoes with low mile drums (sometimes even without turning them),
I have never put on new drums without new shoes.
Ecostang
Nov 3, 2022 08:50 PM
MartinM
Sep 19, 2015 02:11 PM
tacbear
Off-Topic Chatter
Aug 19, 2015 09:05 AM
houtex
Aug 13, 2015 05:04 PM
Rot Manik
1994-2004 V-8
Aug 6, 2015 05:26 PM
