Home garage auto lift
This is a topic I've been thinking about alot also. I've used 2 post asymetrical lifts before but never a 4 post. Since I can't have one of each, I'm trying to decide which option would work best for allowing me to do most everything to a vehicle. Option 1, a 4 post lift for most jobs and a Kwiklift for suspension and brake work. 4 post easier to load but not sure how much access it allows for things like dropping the engine or tranny. Also, how much ground clearance do you need for the kwicklift? I have a racecar that is pretty low. Option 2, a four post with jacktray. How much clearance do you need for a jacktray with bottle jacks? Or would hydraulic jack tray be a better investment? Option 3, 2 post lift only. Would allow me to work on pretty much everything except when I need the suspension loaded. It is more trouble to load the vehicle, especially the racecar because it is difficult to see where the pads are under the car do to the height. Any advice or other options I haven't considered?
I've had one for 5 or 6 years. It's way cheaper than building an extra garage stall, or moving to a house with a larger garage!
My ceiling is about 10.5 feet, if I recall. Only change required was to the garage door tracks (what they call a "high lift kit").
Anyone?
Founding MOTM
Committee Member
Committee Member
Gary, you should put one of these in your new house!
http://www.youtube.com/watch?v=oJaP9...&tracker=False
That set-up posted by kckmustang has me thinking as my garages have 10 ft. ceilings, so a lift might actually work with a high lift track set-up.
Seems to me like the most versatile is a 2 post asymmetrical. There are too many things I'd need to work on for the 4 posts you guys have listed. Unless the only use was for storage. Otherwise, access to the suspension, drive line, engine, exhaust can all be had much more favorably by a 2 post.
Gigantor
5/11/23 07:31 PM
