Camless I6 in the works
Old Sep 15, 2004 | 07:26 PM
USA-Adam's Avatar
Power: 220kW @ 7200rpm
Torque: 460Nm @ 4600rpm (400Nm from 1200rpm)
Bore: 94mm
Stroke: 96mm
Compression Ratio: 10.0:1
Construction: Lightweight Alloy Block and Head, Iron Sleeved Bores, Forged Steel Crankshaft and Rods
Firing Order: 153624
Valve Actuation: 4 Valves per Cylinder, Infinitely Variable Solenoid Actuated Valves
Fuel: Sequential Petrol or LPG Injection
Ignition: Crank Angle Sensor, Coil on Plug, 6 Knock Sensors
Features: Piston Cooling Oil Jets, Electronic Water Pump, Continuously Variable Length Intake Runners, Ceramic Coated Tuned Length Exhaust Headers, Drive-By-Wire
I didn't type that wrong. I don't think this will ever see the Mustang's soul but you never know. For some reason I think the GT owners might be slightly peaved if a 6 banger made comperable torque and horsepower with less liters (3.9) ...
The coolest thing about this engine is the fact it has no camshaft though. It has solenoid actuated valves Not even Indy cars have those .. this is a revolutionary idea. Let's hope Ford doesn't drop the ball. (This motor will first see duty in the Falcon of Austrailia .. as usual we are behind them .. )
Old Sep 15, 2004 | 07:33 PM
Evil_Capri's Avatar
I've read a couple of stories (Ford Aussie sites, and somewhere else . . :scratch: )regarding this engine (and a v8 version), some have stated that this is a hoax, while others seem to varify the design.
I'll see what I can dig up in the next few days when I have some more time. Your are very correct in your assesment of a revolutionary idea . . if/when the motor is released.
Old Sep 15, 2004 | 07:55 PM
Dr Iven's Avatar
Cost is an issue, though, as well. Porsche I6's can put out well over 300hp N/A. But, they cost an arm and a leg. If they can keep cost relatively low, this may be the future.
Old Sep 15, 2004 | 07:59 PM
Evil_Capri's Avatar
Porsche engines are flat 6's. I don't think Porsche every had I6's. :scratch: I know they had I4's (944, 924, 968)
But you have a good point in terms of cost.
Old Sep 15, 2004 | 08:25 PM
sonic98gt's Avatar
There's already a technology out there, proven even on a 5L Ford. No cam, NO VALVES, no oil needed on the top end.
COATES
I don't get why, except perhapse cost, this thing hasn't taken off! Pretty cool stuff if you take the time to read through it.
Old Sep 15, 2004 | 08:53 PM
USA-Adam's Avatar
Originally posted by Evil_Capri+September 15, 2004, 8:02 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Evil_Capri @ September 15, 2004, 8:02 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Dr Iven@September 15, 2004, 7:58 PM
But you have a good point in terms of cost. [/b][/quote]
Yeah, flat or boxer sixes are MUCH different than an I6. Flat or boxer just means they are horizontally opposed cylinders.
Old Sep 15, 2004 | 08:57 PM
Galaxie's Avatar
I Have Admin Envy
Siemens has been doing quite a lot of development on solenoid actuated valves.
This is the wave of the future, a lot of frictional losses from the camshaft(s) will be eliminated.
Old Sep 15, 2004 | 09:09 PM
jc69Stang's Avatar
COATES
I remember reading about that a few years back. I don't know why it hasn't taken off either. Really cool stuff. B)
If I remember right, they put it on a Ford 302 and it made impressive power.
Old Sep 15, 2004 | 09:38 PM
2ndGenStangOwner's Avatar
When I was in trade school in '91 one of my teachers told us about the technology,and the big three in Detroit had been working on it for a few years. Even back then they had major durability problems with it. No manufacturer will produce a new technology that won't last at least 36K miles
Old Sep 16, 2004 | 06:44 AM
mr-mstng's Avatar
...and Bosch as well. I see a lot of 'X'-by-wire systems that we are looking to get into.
Old Sep 16, 2004 | 12:15 PM
Merc Ghost's Avatar
Formula One engines are camless as well.
Old Sep 16, 2004 | 04:50 PM
Dr Iven's Avatar
Hmm... I stand corrected.
Regardless, if cost cannot be kept low, what good is the technology?
Old Sep 16, 2004 | 06:11 PM
FrankBullitt05's Avatar
The great thing about camless engines is the fact that they can be very finely controlled...each cylinder can have different valve timings and such... I'm sure that with the right design, they could outlast current engines.
Maybe we'll see it in an BMW M beater, I wouldn't mind :drive:
Old Sep 16, 2004 | 08:18 PM
mr-mstng's Avatar
The cost will eventually come down as it always does. the technology filters down through the ranks to the lower models eventually.
Old Sep 17, 2004 | 12:04 AM
Rakshas's Avatar
I don't know If I can trust it, lot of things could go wrong.
Old Sep 17, 2004 | 01:41 AM
hatsharpener's Avatar
http://www.me.sc.edu/research/AARG/history.htm
http://www.me.sc.edu/Research/AARG/Thesis%20Final.pdf
09-gt/cs
Oct 15, 2015 10:03 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Sep 24, 2015 08:15 PM
