An Altrenative to Jack Stands
Any info on these, looking at the Wheel Cribs 8 to 10 inch ones instead of using jack stands.
http://www.raceramps.com/store/shopd...at=Work+Stands
Since I don't have a lift, jackstands have given me a little more versatility. With those wheel cribs you can't do brake work or rotate your tires. Plus with either jackstands or wheel cribs, you are still jacking up the car in the first place so having wheel cribs doesn't really save you any work... unless you are concerned about the stability of your car up on stands. I use ramps when I can and jackstands when i have to.
They're good if you don't want ramps, and you need all the room you can get under your car. But as mentioned, they're for working under your car, not for brake jobs and things like that. (which I would think would be pretty obvious).
Feb 10, 2017 07:12 PM
robjh22
Sep 8, 2015 12:31 PM
