Please post your dyno numbers along with your car's mods!
With C&L CAI/Predator, SLP PowerFlo axlebacks (auto trans, stock rear gears):
270 rwhp @ 5634 rpm 319 ft/lb tq @ 3894 rpm Temp was 64F. A/F ratio stayed between 12.4 - 12.9 from 4100-5900rpm. Done by JBA Racing, San Diego, CA on a Dyno Dynamics. [There were also a couple interesting items of note. First, they made both of these pulls in 3rd gear. It seems they couldn't keep the auto tranny from downshifting when they hit the throttle in 4th. However, during a full dyno tune session, they have a way to electronically "lock" the tranny in 4th gear. I also asked about the correction factor for the Dyno Dynamics system they use. They said that it uses a correction system that will result in lower numbers than say a DynoJet. In fact, JBA has tested both systems. Using a test car, they made a pull on their own dyno and then immediately took it to another shop who uses a dynojet for a comparison pull. The pulls were made about 30 minutes apart, and the dynojet reported about 20 rwhp more than their own dyno.] |
Originally posted by don_w@July 18, 2005, 7:16 PM With C&L CAI/Predator, SLP PowerFlo axlebacks (auto trans, stock rear gears): 270 rwhp @ 5634 rpm 319 ft/lb tq @ 3894 rpm Temp was 64F. A/F ratio stayed between 12.4 - 12.9 from 4100-5900rpm. Done by JBA Racing, San Diego, CA on a Dyno Dynamics. [There were also a couple interesting items of note. First, they made both of these pulls in 3rd gear. It seems they couldn't keep the auto tranny from downshifting when they hit the throttle in 4th. However, during a full dyno tune session, they have a way to electronically "lock" the tranny in 4th gear. I also asked about the correction factor for the Dyno Dynamics system they use. They said that it uses a correction system that will result in lower numbers than say a DynoJet. In fact, JBA has tested both systems. Using a test car, they made a pull on their own dyno and then immediately took it to another shop who uses a dynojet for a comparison pull. The pulls were made about 30 minutes apart, and the dynojet reported about 20 rwhp more than their own dyno.] So what is the real numbers then? 280 horsepower or the lower numbers you have posted? |
300 rwhp 315 rwtq
C&L 93 Octane Predater/Tune with C&L CAI Note: 4 points to the rich adjustment at WOT in both power bands Bassani axelbacks, x-pipe, comp cats. |
270 rwhp done by K&N. Didn't see an tq numbers on the dyno sheet though :dunno:
Car is all stock. |
299rwhp 309rwtq on a Dyno Jet. 97 degrees, humidity 14%.
Steeda CAI, C&L intake tube, Steeda UDPs, custom tune |
Stock, mine did 272hp and 292torque.
At the time, no mods and only 1500 miles on the car..
RWHP= 261 Torque= 284 |
Saleen supercharger 4 psi boost.97 gegrees. There tune
362rwhp 365rwtq |
277hp and 282 torque, car is bone stock, was done on a Mustang Dyno in 90-degree heat. I'm suprised the numbers were that high, especially for an automatic.
Dyno'd mine on last Sat. on a dynojet. 91 degrees 298rwhp and 309rwtq. Mods: K&N Intake, Steeda UDP, Magnaflow HI-Flow X-Pipe, JBA axle-back, and Diablo custom tune.
Stock pulls are in the sig, with 700 miles on the car. I just ran it today and with JLT CAI, DTP 93 octane Predator tune, ProChamber welded to stock cats and 4.10 gears (they don't add hp/tq, but they do skew the readings), I pulled 280rwhp and 297rwtq on a Mustang Dyno.
I have a bullitt with C&L intake, Mass air kit, Pro Chamber H-Pipe with no cats and dyno tuned.
Rwhp 248.6 torque 294.3 |
I feel a little bummed out got my car dynoed today with MTAS and my best pull was a 246 and that is with a K&N and predator 87 tune
Originally posted by pmcarlino@July 22, 2005, 8:23 PM Saleen supercharger 4 psi boost.97 gegrees. There tune 362rwhp 365rwtq |
SLP/ATI PROCHARGER 9-10psi/ MUSTANG DYNO:
HP= 393.2 TQ= 365.5 Thank gowd you cant supercharge 2005 mustangs.. they just cant handle it :nice: |
Originally posted by lostsoul@August 11, 2005, 1:46 AM SLP/ATI PROCHARGER 9-10psi/ MUSTANG DYNO: HP= 393.2 TQ= 365.5 Thank gowd you cant supercharge 2005 mustangs.. they just cant handle it :nice: |
Originally posted by adrenalin@August 11, 2005, 12:03 PM what? You say you have a procharger and then say "thank gowd (your spelling not mine) you cant supercharge 2005 mustangs." |
Sure you can put a supercharger on a stock engine, but everyone asks the same thing, how long will it last before failing. 50,000, 100,000 miles, who knows. I'm still not ready to supercharge mine yet.
Originally posted by adrenalin@August 11, 2005, 10:53 AM Sure you can put a supercharger on a stock engine, but everyone asks the same thing, how long will it last before failing. 50,000, 100,000 miles, who knows. I'm still not ready to supercharge mine yet. |
