Windshield Washer Fluid Problems
Old Sep 11, 2008 | 05:27 PM
silstang23's Avatar
I took out my windshield washer nozzles to put my stripes on. To do that I had to remove the tubing that connects to the nozzles from underneath the hood. Now my problem is the tubing won't stay on the nozzles when I try to apply the windshield washer fluid, like the pressure is making it come off the nozzles. Anyone else have this problem or know what to do? I mean when I took them off the tubing just unplugged from the nozzles and when I plugged it back in they just won't stay on.
Old Sep 11, 2008 | 05:34 PM
RRRoamer's Avatar
The tubing is over stretched. You might try trimming about 1/4" to 3/8" off the end of the tube to get "fresh" tube on the nipple and see if that works.
If it doesn't, you could always get some silicon tubing that is about the same O.D. of the nozzle tubing and cut a piece about 3/8" long. Use a pair of needle nose pliers to stretch it out and insert the nozzle tubing into the silicon tubing. After putting the nozzle tubing back on the nozzle, slide the silicon tubing up over the tubing/nipple. It will clamp down on the tubing and prevent it from coming off.
I've used this type of "hose clamp" on the plumbing of my RC helis for years with no problems at all.
Old Sep 12, 2008 | 08:29 AM
Robbieg's Avatar
You could also try some small zip ties as clamps, get them nice and tight and they should hold well. Simple fix.
Old Sep 12, 2008 | 09:09 AM
I like the trim a 1/4 inch off the ends idea. I'm betting that will werk
Rando
Aug 25, 2021 11:12 AM
yabutt
Oct 23, 2015 01:05 PM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
Rando
Sep 30, 2015 12:28 PM
