"Whirr" sound from trans.
Old Oct 24, 2005 | 08:59 AM
I8URVTEC's Avatar
Anyone else getting a loud "whirrr" sound from their manual transmission? I noticed it now that it is starting to get cold and I called the dealer and they said if you notice it any other time than when it's cold bring it in. It goes away when the trans warms up. Is this normal? Any ideas?
Old Oct 24, 2005 | 09:11 AM
adrenalin's Avatar
Mine was doing it a bit last year so I drained the differential and put in Mobilube HD LS 80W-90. Have not heard it since.
Old Oct 24, 2005 | 09:15 AM
I8URVTEC's Avatar
Hmm, I guess it could be the diff. This sound seems to be coming from right below the shifter but then again it is tough to pin point it exactly while driving.
Old Oct 24, 2005 | 09:18 AM
adrenalin's Avatar
You might want to change the fluid in the tranny. Mine isn't making that noise but if it was, that would be the first thing I changed.
Old Oct 24, 2005 | 09:46 AM
I8URVTEC's Avatar
Does it make sense though that it only happens when cold? I know the fluid is less viscous when cold.
Old Oct 24, 2005 | 10:55 AM
adrenalin's Avatar
Well I think it does. Since the oil is less viscous it takes longer for all of the parts to get lubricated properly. Forgot to ask, how long does it take before the noise goes away. 30 seconds, 1 minute, etc.
Old Oct 24, 2005 | 11:11 AM
I8URVTEC's Avatar
Usually about 3 to 5 minutes if the car is completely cold i.e. if it sat over night. Also, I can hear the sound most prominantly at lower RPMs such as when I am crusing in 5th gear at around 55 mph.
Old Oct 24, 2005 | 11:21 AM
adrenalin's Avatar
I'd get the dealer to take a look at it. The temp around here is about the same where you live and my car doesn't make that noise. Hard to say if it is the tranny or something else that is just resonating back to that location.
Old Oct 24, 2005 | 11:58 AM
I8URVTEC's Avatar
It's due for an inspection next month anyway and I am having them do it so I think I will have them check that out too.
Old Oct 24, 2005 | 12:07 PM
Tsbird1994's Avatar
you don't need that P.O.S. '05 ... Just give it to me... or you could unload about 150 rounds fromt eh MINI-14 in it
jk!
Old Oct 24, 2005 | 12:29 PM
gkaufman's Avatar
sounds like the tsb problem to me. I have the same issue. When was your car built?
Old Oct 24, 2005 | 01:26 PM
I8URVTEC's Avatar
jk!
Very funny Tom and you are not getting my car.
I don't have an exact build date. I took delivery last November so it was built sometime before that.
Old Oct 24, 2005 | 02:53 PM
Infinity's Avatar
Mine does it also. I thought it was maybe the synchros kicking in. I didn't notice it until I was riding around with my mom and wife Sunday. They could both hear it also. It definitely comes through the shifter, though, because I can feel the resonance in the handle.
Old Oct 24, 2005 | 08:22 PM
RaGsHoCkEy88's Avatar
yes i get it too
Old Oct 25, 2005 | 06:32 AM
I8URVTEC's Avatar
Have any of you guys called or been to the dealer about it?
Old Oct 25, 2005 | 07:18 AM
gkaufman's Avatar
they are ordering the parts to the tranny as we speak. Did you read the tsb regarding this tranny noise?
Old Oct 25, 2005 | 08:56 AM
I8URVTEC's Avatar
No, do you have a link to the TSB. I haven't seen it yet. The only ones I have seen regarding noise from the drivetrain were regarding the rear end.
Old Oct 25, 2005 | 09:08 AM
I8URVTEC's Avatar
I think I just found it. This the one?
http://www.bradbarnett.net/mustangs/galaxi...8tranygrowl.pdf
I made an appointment with my dealer.
Old Nov 3, 2005 | 01:42 PM
atomicskiier01's Avatar
I have this problem, there is a really loud "whine", but it only occurs when I am giving it gas at about 55mph in 5th gear. Have you found a solution to this yet???
Old Nov 3, 2005 | 02:22 PM
Packoo's Avatar
TSB says build dates before 1/25/05 but mine was built in August, still apply?
Rando
Aug 25, 2021 11:12 AM
Rando
Sep 30, 2015 12:28 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
oldnjguy
Sep 10, 2015 02:39 PM
