What in the world are these things?
Old Jan 22, 2008 | 03:03 AM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Two things, actually.
The first. The map lights assembly has two small holes They look like temp. sensors but they're not.
The second. On the tach right under 4k rpm's, there's an arrow pointing directly up. It doesn't light up, it doesn't blink, its not even listed in the manual! Just discovered this the other day and I was wondering what it is.
Any ideas?
Old Jan 22, 2008 | 03:39 AM
Cocheese's Avatar
Holes near your map lights are motion sensors for the active anti-theft
The arrow is... Oh yea, I have no idea, since I havn't been in my car for three months... winter sucks
I got half of your questions anyways
Any ideas?
Old Jan 22, 2008 | 04:42 AM
Cavero's Avatar
+1 on the motion sensors
I'm pretty sure the arrow is a shift light that Ford decided not to enable. My mother's last car had one just like it that lit up when it was time to upshift and it got really annoying.
Old Jan 22, 2008 | 05:45 AM
Founding MOTM
Committee Member
Interesting about the shift light. It would have been nice to be able to activate/deactivate that from the dash. Oh well. Thanks for the answers guys!
Old Jan 22, 2008 | 06:21 AM
poldrv's Avatar
They are part of the alarm system (sensors) you couldn't ask for better holes.
Old Jan 22, 2008 | 07:40 AM
AWmustang's Avatar
doubt you would have actually wanted them... they are usually set to come on for max MPG so it's basically useless.
Old Jan 22, 2008 | 09:11 AM
StangNut's Avatar
Yes, the shift light was originally intended to be used on the "new" Mustang, but so many people complained about it they left it off. It's not even there in '05's. At least not in mine. I'm not sure about the '06's. The GT500 has it and it's enabled, as far as I know. The cool thing is you can disable it yourself or just change the shift settings yourself.
Old Jan 22, 2008 | 09:12 AM
metroplex's Avatar
The PCM has a setting to enable/disable the shift light. I haven't been able to confirm if the LED is actually connected, but I see the various settings via my SCT Advantage software. It can be adjusted for max MPG or max acceleration.
The GT500 has 2 shift lights and an audible buzzer.
Old Jan 24, 2008 | 02:31 PM
spike's Avatar
This is an old thread that discusses this at length.
http://forums.bradbarnett.net/showthread.php?t=57141
Summary: It was originally intended to come on to tell you when to shift for best gas efficiency (~2500 rpm) but was ultimately not activated in the S197. BamaChips tried to get it to work as a shift light but was not successful. GT500 currently has an adjustable one with an audible beep. The thread then digressed into just buying a raptor shift light.
Old Jan 24, 2008 | 07:53 PM
StangNut's Avatar
Correct me if I'm wrong, but I don't think there's anything at all there in an '05. Not even the arrow.
Old Jan 24, 2008 | 08:45 PM
05BLKGT's Avatar
I have an arrow in my 05.
Old Jan 25, 2008 | 10:47 AM
jayguy's Avatar
I have an arrow on my '07, and had one on the '05. It's hard to see, you have to have the lighting just right, but it's there. Like stated above though, there might not be a light behind it, and it's not activated.
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
MustangConvert11
Sep 30, 2015 08:01 PM
GLOCKer
Sep 28, 2015 05:20 PM
