What is this under the back bumper?
You're right, it's not the fuel tank...it's the..
Onboard refueling vapor recovery..
From Wikipedia...
Onboard Refueling Vapor Recovery (ORVR) is a vehicle emission control system that captures fuel vapors from the vehicle gas tank during refueling. The gas tank and fill pipe are designed so that when refueling the vehicle, fuel vapors in the gas tank travel to an activated carbon packed canister, which adsorbs the vapor. When the engine is in operation, it draws the gasoline vapors into the engine intake manifold to be used as fuel. ORVR has been mandated on all passenger cars in the United States since 2000 by the EPA. The use of onboard vapor recovery is intended to make vapor recovery at gas stations obsolete
From Wikipedia...
It's the same on almost every Ford. Steve, go look under your police car in the same location. My Crown Vic has that, and so does the E-250. There's an evap air intake solenoid that allows fresh air to enter the fuel tank to bleed out any vacuum. Spiders like to lay eggs in this hose.
houtex
05-09 Exterior Modifications
13
Apr 17, 2025 10:53 PM
robjh22
Custom Vanity Personalized License Plates & Brackets /Delete Brackets
14
Nov 1, 2015 11:28 PM
glo106
Aug 11, 2015 08:29 AM
