What part is this? And where does it go?
Old Feb 14, 2013 | 06:58 AM
joeblackis's Avatar
What part is this? And where does it go? Solved !!
2007 stang.
I got an oil change a few months back and the guy took these out of my car, somewhere under the hood and told me that my car is better off not to have them inside it. They were full of leaves and dirt at the time when he removed them.
I didnt see where he took them out, but I am thinking I should put them back where they are suppose to go. I looked all over under my hood but couldnt see where they would fit into.
Pics included
Attached Thumbnails What part is this? And where does it go?-img_20130214_085241.jpg   What part is this? And where does it go?-img_20130214_085250.jpg   What part is this? And where does it go?-img_20130214_085237.jpg
Old Feb 14, 2013 | 07:06 AM
They've got to be from under the car where the cowl area of the hood drains underneath.
Old Feb 14, 2013 | 07:23 AM
SilverSkoundrel's Avatar
I would think they were there originally for a good reason
Old Feb 14, 2013 | 07:29 AM
joeblackis's Avatar
I remember he was able to remove them from reaching under the hood when it was propped up. He stuck his hand pretty far down to grab them and take them out.
It was a manager at a ford dealer who did it, as I was showing him the bubbling issue on my hood .
Old Feb 14, 2013 | 07:36 AM
Well hmm. Now I wanna know lol
Old Feb 14, 2013 | 07:40 AM
SoFlaBoss's Avatar
Bingo! They do get blocked by debris (leaves, triggs, etc.) then cause water to pool up inside the cowl area, which then overflows into the cabin, usually damaging the electrical of your Smart junction Box over on the passenger side footwell. I would just reinstall them and make sure they aren't blocked, and maybe replace your cabin air filter while you're at it.
Old Feb 14, 2013 | 07:42 AM
Stupid cabin air filter lol
Old Feb 14, 2013 | 07:53 AM
joeblackis's Avatar
Thanks for the replies!!
I found this post too
https://themustangsource.com/f739/co...-clean-504787/
It looks to be around the same area of where the guy was sticking his hands tp pull them from.
I will have to find out how to change the cabin air filter first Is that an easy task?
I work with computers. Not cars
Old Feb 14, 2013 | 08:01 AM
SoFlaBoss's Avatar
Yes, it's very easy to change.
Old Feb 14, 2013 | 08:08 AM
joeblackis's Avatar
So both of the areas are vertical and the rubber drainthings just goes point straight down, but with the smaller tips at the top , seems pretty pointless to have them in there. I put them in , by the way the slots are not visible I had to slide my hand all around to finally find the slots, They both snapped right into place though.
Old Feb 14, 2013 | 08:10 AM
joeblackis's Avatar
great, thanks!
Old Feb 14, 2013 | 07:12 PM
Nunja Business's Avatar
"Smaller tips at the top" just sounds logically wrong.
Did you try putting them in the other way?
I plan on climbing into my engine compartment this weekend, so I will be looking at mine!
Old Feb 14, 2013 | 07:45 PM
Cavero's Avatar
That does sound wrong. They should be like funnels, with the narrow flat side pointing down.
Old Feb 15, 2013 | 12:17 PM
joeblackis's Avatar
OK looks like I put them in backwards! lol. I know where they go now from looking at that other picture.
The guy that removed them also said he usually just cuts the tips of them off to make the opening bigger too.
I am not sure why these are even needed, at least in my 07 they seem really pointless because the opening just directly points to the ground.
Let me know what you find on yours!
Oh I managed to change the air cabin filter!.
First time in 5 years!!
It was pretty dirty. But I only have 15k on my stang.
Old Feb 15, 2013 | 01:03 PM
joeblackis's Avatar
Installed correct way now.
Attached Thumbnails What part is this? And where does it go?-111.jpg   What part is this? And where does it go?-2222.jpg
Old Feb 16, 2013 | 09:09 PM
nascar_red's Avatar
Leave Them Out - or - if you reinstalled them take them back out. They will fill with debris and you WILL have a waterfall into the passenger foot-well. There is a very informative thread on allfordmustangs.com
Old Feb 17, 2013 | 06:37 AM
Yepper, I am removing mine.
Old Feb 17, 2013 | 11:55 AM
Coupe Guy's Avatar
BMW had a similar issue on the older 3-series (E-30). It would probably be best to remove them and to cut the tips off where they seem to be pinched together. This will allow small debris to go through without clogging, while directing the water downward.
trackpack13gt
Jul 25, 2017 05:29 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Steve@CJPP
Sep 24, 2015 06:58 PM
Steve@CJPP
Sep 3, 2015 10:43 AM
