Warranty about to expire, what to get checked?
Old Jul 29, 2008 | 07:46 AM
Reminisce's Avatar
Hey guys,
My wonderfully faithful and problem free GT has been putting on some serious miles in the last year or so, and I'm now about 300 miles from my warranty expiration. I was wondering if there is anything I should try to get done at the dealer before that happens? So far the only thing I need to get looked at or replaced is my front right headlamp, which has condensation in it, and maybe some minor creeking from the right side of the suspension.
I change my own oil and filter, I'm about to change my fuel filter, not worried about the intake system as I recently cleaned my JLT and throttle body. Just recently had it in the collision center because my fiance backed into it (another story) and they pretty much repaired every scratch on the car, so the body looks good. Anything you guys think I should get done to it before I run the 300 miles off?
Thanks!
Old Jul 29, 2008 | 07:50 AM
dustindu4's Avatar
9 is not my lucky number.
if it aint broke don't fix it
Old Jul 29, 2008 | 12:27 PM
krnpimpsta's Avatar
Do you have leather seats? Are they worn? I hear you're allowed to replace them exactly once under warranty for being worn.
Old Jul 29, 2008 | 05:19 PM
SONICBOOST's Avatar
Check into some superchargers!
Old Jul 29, 2008 | 06:53 PM
do your strut mounts pop or make noise over bumps? Any squeaks or rattles? Brake fluid reservoir leaking?
Old Jul 30, 2008 | 05:55 AM
Mustangfreak's Avatar
Look for parts needing replacement and have them replaced. How can we know what your car needs?
Old Jul 30, 2008 | 07:55 AM
goldenpony's Avatar
Warranty
If it were me, I'd ask the dealer what their position would be on a plug change. Sometimes, a dealer will perform a plug change while the car is still in warranty, sometimes they won't. I would be curious if they put new plugs in, and you just paid for the plugs & normal labor. IF they break any plugs, will they cover the cost of removing any broken plugs under warranty? Some will, some won't. Might be worth at least asking.
Old Jul 30, 2008 | 08:32 PM
Reminisce's Avatar
Good info, I ran by there today, leaving the car tomorrow as I am going out of town for the weekend. Adam's advice is the best! I will ask about spark plugs and suspension as well, thanks guys!
Old Jul 31, 2008 | 12:12 PM
Boltzman's Avatar
Originally Posted by Reminisce
Hey guys,
Thanks!
To get the headlite replaced they have to remove front fascia which almost guarantees that you'll end up w/scratches of some sort. They are not very careful IMO
Old Jul 31, 2008 | 12:26 PM
WaltM's Avatar
Did you have the exhaust rattle TSB done? Get it while it's free; it makes a world of difference.
Old Jul 31, 2008 | 03:45 PM
red454's Avatar
Right before my warranty was up I had them check the battery and the fuel pumps (surge problem). The dealer replaced the battery and the pumps...
Old Aug 1, 2008 | 06:15 AM
vicmeldrew's Avatar
you would be smart if you have an 05 to get the fuel pump changed; tell them you get the hesitation after a long cruise (in a tsb); i actually had this problem and almost got killed once when i pulled out to pass; also, i didnt put too many miles on mine and didnt show up until well into the third year of ownership; only takes about an hour to fix. well worth it;
Old Aug 1, 2008 | 06:36 AM
poldrv's Avatar
I would buy and extended warranty and be essentially worry free for 3 or 4 more years.
FordESP.ca - Discounted genuine Ford extended warranties available online
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
