Vibration sound coming from shifter area
Old Apr 22, 2007 | 10:34 PM
max2000jp's Avatar
I am all of a sudden getting a rattling sound coming from the transmission area. I went under the car today and looked to see if my Saleen short throw was loose, but everything checked out okay. Any other ideas?
Old Apr 23, 2007 | 11:39 AM
LimeZoSo's Avatar
May or may not be your problem, but when it rattles, try holding the plastic part of your e-brake. I had a rattle coming from the same area and finally found out that its the plastic part of the e-brake. I am trying to figure out a fix for mine now. Don't know if that will help or not. Just a thought from personal experiance.
Old Apr 23, 2007 | 01:36 PM
97svtgoin05gt's Avatar
To be safe have the u-joints checked. When my u-joint went bad on my '86, the vibration started and then became much worse as time went on. It eventually ruined the trans etc.
Old Apr 23, 2007 | 01:46 PM
max2000jp's Avatar
I am 99.9% sure it's the shifter linkage. I played around a bit with it today on my way to work. The noise went away when I applied side pressure to the shift know when I was in gear. I bet the dang shift linkage on the trans has come loose. I should just take it into the dealer and have them look at it, but they will probably blame my Saleen shift adaptor.
Old Apr 23, 2007 | 07:47 PM
Bullitt995's Avatar
Keep me updated on that fix will ya?
Also, I think I have that same vibration and I have a Pro 5.0 shifter. Does it feel like it's coming from around your feet?
Old Apr 25, 2007 | 11:43 AM
Bullitt995's Avatar
Any updates on this?
Old Apr 25, 2007 | 05:27 PM
max2000jp's Avatar
I haven't had time to get unter the car. It's definetly something related to the shifter. If I put lateral pressure on the shifter, the vibration stops. I am almost positive the bolt that connect the linkage to the trans has vibrated loose.
Old Apr 26, 2007 | 08:59 PM
Bullitt995's Avatar
Mine doesn't stop when I put pressure on the shifter and I've tightened everything on the shifter so that's not it for me atleast.
bob
Aug 15, 2015 08:58 AM
Mackitude
Aug 13, 2015 01:05 PM
SilverBullet13
Aug 13, 2015 09:11 AM
dontOverSteer
Aug 11, 2015 05:28 PM
Mug-stang
Jul 31, 2015 10:25 PM
